> Clutch Slipping
post Sep 23, 2009 - 8:44 PM
Ruroniarc
Joined Mar 19, '09
From Malden, MA
Alright, so I'm pretty sure my clutch is going. Here's what's happening, and I'm just wondering what parts I need in this kind of situation. And possibly about how much the parts cost, and how much work it would be to do it myself.
Alright, if I have it in like 4'th gear around 40-45MPH, and I floor the gas, my RPMs take off, and my speed stays the same. Indicating, to me at least, that the clutch it slipping. So what would I need to replace it? I don't really need a high performance clutch, just OEM replacement would be fine.
post Sep 23, 2009 - 9:00 PM
oem style clutch with plate and bearing 200
flywheel resurfacing 45 - 65
trannny seals 20- 45 bucks
3 qts of oil tranny 25 bucks
optional
rear main seal (25bucks)
fipg (10bucks) to seal oil pan.
bruises, scratches, cuz words and frustration priceless...
am i forgetting something,
post Sep 23, 2009 - 9:02 PM
Ruroniarc
Joined Mar 19, '09
From Malden, MA
What is the time involved? Can it be done by 1-2 people? Is it an extremely hard job? What do I need to remove to get to my clutch? (ST)
post Sep 23, 2009 - 9:22 PM
solidxsnake
Joined Apr 20, '09
http://www.6gc.net/forums/index.php?showto...mission+removal
~Moving on to a 2002 Corolla S~
R.I.P Tom Celica - 1994-2010
post Sep 23, 2009 - 9:55 PM
Remy
Joined Jan 25, '06
From MN
I just got done doing mines on a s54 by myself (first time)the only time I needed help was to help guide in the tranny back in. I would recommend you get at least 2 people so it can be done faster and you will have to take everything attached to the tranny apart just an idea of what you will be doing. You will want to get new gaskets for your tranny drain and refill bolts I think they're crush gaskets I've had to get new ones everytime I take my axles apart to do work on the car they leak if you reuse them. Having a car manual helps too. Its not too bad if you know your way around the car or cars lol.
Also a good video to look at in the stickies.
http://www.6gc.net/forums/index.php?showtopic=34164
Clutch kit
Resurfaced flywheel or New flywheel
Drain/Refill tranny bolt gaskets
Blue Thread Sealer for flywheel bolts
Torq Wrench/rachet
Basic tools I did it with no power tools
Car manual
If you want a new fork
MP grease
Trans fluid
Brake fluid for master/slave clutch cylinder
And anything else you want to change while your down their new motor mounts, axles, axel seals, etc...
"To Protect And To Serve The Wealthy" -POLICE
post Sep 24, 2009 - 12:30 AM
Ruroniarc
Joined Mar 19, '09
From Malden, MA
http://cgi.ebay.com/ebaymotors/Toyota-Camr...s#ht_1090wt_939
Is this legit? Has anyone heard of this company / used their products?
Also, do I have to get the rest of the parts like the tranny seals / bolts / gaskets at a Toyota dealer? Thanks.
post Sep 24, 2009 - 2:36 AM
Joe_1985
Joined May 3, '09
From jacksonville/flemming island florida
actally the oem factory clutch (which is the best u can get for longeveity reasons) is about 150 ish from 1sttoyotaparts.com
try bleading your clutch 1st if the fluid's dirty, mine randomly slips but normally grabs fine, i think its my fluid and my slave cylinder
94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine
85 celica gt-s project
post Sep 24, 2009 - 10:23 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
OEM clutch is good (I'm on 221K on orig factory clutch), but it would probably be best to buy an OEM spec or stage 1 Exedy.
But if money is tight i'd stick to the factory unit. Can't go wrong there.
**** Photobucket
Lo-Fi Version Time is now: January 12th, 2025 - 7:38 AM
