![]() Enthusiast ![]() Joined Jan 12, '03 From HollyWood CA Currently Offline Reputation: 0 (0%) ![]() |
Hi i had got one before but mine was plastic didn't really work.
what do you think Click Here |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
Those things are complete ripoffs! Think about it. A real turbo setup is probably going to cost you at least $2000. Buying a $150 turbo system is not going to help you. That description is pretty funny though.
"...and you get the sssss noise that actual turbos make..." "...make it a cold air turbo..." -------------------- New Toyota project coming soon...
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) ![]() |
a real turbo uses exhaust gasses from the engine to spin the turbine
this one uses electricity thats drawn from your cars electrical system electricity is made via the accessories pulley that your engine spins so basically its using power from your engine to make up for lost power it might be good for 1 or 2 hp, but a better investment is a underdrive pulley which will give you 8 hp for the same basic function wow that was confusing, mb someone can offer a better explantion ... I need some coffee |
![]() Enthusiast ![]() ![]() ![]() Joined Dec 27, '02 From Sleep in Warren chill in clinton twp, works/school in detroit Currently Offline Reputation: 1 (100%) ![]() |
stay away from those B.S son
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) ![]() |
he made that....
![]() check out what he bought to do it Honda Blower Motor shoot, for 5 bucks and some tubing+clamps, i think i will make it too and resell it for $160 ![]() -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) ![]() |
Have you ever seen the pump that pulls water out of a washing machine? That's what it looks like.
You know, with some thought, that's a good concept. If you could find a way not to use so much power. I wonder if you used an audio lightening cap and had a toggle switch to turn it on and off for special occasions how it would work. How much pressure did it claime to put out? |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) ![]() |
one of my friends did this on his 1st gen eclispe and it does make a little bit of a difference but not a $160+ difference... make it yourself if you that interested in it
-------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Lo-Fi Version | Time is now: February 22nd, 2025 - 3:36 AM |
