engine problem, need help car not running right |
Sep 24, 2009 - 10:48 PM |
Enthusiast Joined Sep 23, '09 From minnesota Currently Offline Reputation: 0 (0%) |
my 2000 celica gts has slow acceleration? when step on the gas it slowly move foe a few sec then it will go? i dont know what is causing it. One of my freind say it might be injector and one say it might ground misplacement. is like the car is being hold down. i try stepping all the way it still start slow for at leas 4-5 then move normal again.
Sep 26, 2009 - 10:28 PM |
Check Engine light on?
Any codes in the history? Autozone does free code checks. -------------------- |
Sep 27, 2009 - 2:03 AM |
Enthusiast Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
replace your ground wires for ECU and Injectors, also 00' is a 7th gen, might get more info from there forums?
Sep 27, 2009 - 11:05 AM |
try newcelica.org
Sep 27, 2009 - 7:29 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Is that the black gts celica with gt rims ?? I knew a guy who had the same problem his cousin who is a toyota tech said those 7th gens had some faulty ecu's when they came out he replaced his ecu and it fixed the problem.
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Sep 29, 2009 - 8:49 PM |
no code no engine check!
Sep 29, 2009 - 8:53 PM |
ill put new ground and see if it solve the problem. but ill have my freind take a look at it.
Lo-Fi Version | Time is now: January 12th, 2025 - 8:48 AM |
