> Low RPM stalling
post Sep 29, 2009 - 10:33 AM
Ponchoz
Joined Sep 29, '09
From San Antonio
Guys - Newbie to the forum so bear with me. I have a 95' GT auto. Recently, I have been having trouble with the car stalling out at low RPMs. Car cranks and idles fine when the car is cold. After I start driving it and it is warmed up it will stall every time I come to a stop. The car will shake, rpms drop and then it just dies. So far I have replaced the fuel filter, plugs, wires, cap & rotor. Still same problem. No codes or check engine light have come on. Any thoughts or advice? Thanks in advance...
post Sep 29, 2009 - 5:30 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
check your idle speed control valve
God made man....
Everything else...
Made in China
post Sep 29, 2009 - 5:45 PM
Remy
Joined Jan 25, '06
From MN
I had the same problem on my car 3x, first time my map sensor crapped out on me didn't throw any codes but I tested it just in case tested bad replaced it and now it runs just fine. The second time this happened I cleaned my IACV and it solved the problem. Third time found out it was my fuel filter but I know you replaced that already another reason why this can happen could be because of a bad dizzy/coil so check that too. All this happened months apart from each other so it could be alot of things.
"To Protect And To Serve The Wealthy" -POLICE
post Sep 30, 2009 - 9:25 PM
Ponchoz
Joined Sep 29, '09
From San Antonio
Thanks guys! That will give me a place to start...
Lo-Fi Version Time is now: December 4th, 2024 - 5:38 PM
