> FS: Cleaning out the garage
post Sep 29, 2009 - 12:09 PM
6strngs
Joined May 12, '06
From Wilmington, NC
Trying to clean out my shed a little bit. Pictures of anything available by request
5sfe valve cover $30 Shipped
5sfe intake manifold $15 + shipping ($35 shipped?)
5sfe throttle body $20 shipped
5sfe timing covers (all) $12 shipped
5sfe head, no cams $10 + shipping (around $40-65 shipped?)
worked fine, 162K miles, recommend it be rebuilt
5sfe block, pistons, rods, etc. FREE w/ PICKUP
metal shavings got inside, don't know if it's rebuildable or not
5sfe oil pan for 5sfte $10 + shipping ($25 shipped?)
has bung welded on it for custom -10an oil drain line, will come with custom oil feed and drain line that can be bolted to a CT26, CT20B, or CT27 turbo. I spent ~$150 for this
3" intake for 5sfte $25 shipped
This post has been edited by 6strngs: Mar 9, 2010 - 9:04 PM
post Sep 29, 2009 - 2:09 PM
ravinaziankid
Joined Sep 11, '09
From NYC
Would happen to have the stock oil pressure sensor or sender that screws into the block?
post Sep 29, 2009 - 2:41 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (ravinaziankid @ Sep 29, 2009 - 12:09 PM) *
No, only the one currently in my running car... I have about 2 broken ones, and one from a 5th gen, but that one uses a different connector... not much help, sorry
post Sep 29, 2009 - 2:54 PM
ravinaziankid
Joined Sep 11, '09
From NYC
Thanks..I was actually just looking for the wire connector that goes from the harness to the sensor clip thing. My wire snapped on it and so now I'm in the hunt for a new one. Does it come with the wires when bought brand new? I see some online but the pics don't show the wires.
post Sep 29, 2009 - 3:36 PM
A_N_T_H_O_N_Y
Joined Aug 29, '09
From Ottawa, ON, Canada
Pics of the intake?
post Sep 29, 2009 - 7:45 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (ravinaziankid @ Sep 29, 2009 - 12:54 PM) *
Ah, you should of said so! I have 2 spare wiring harnesses, I probably have the connector.
I'll get a pic of the intake in a little bit
post Sep 29, 2009 - 9:21 PM
those spare wiring harness that you have, how are they, ill prolly need one to lenghten my swap, do u have pics and price.
post Sep 30, 2009 - 1:43 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (njccmd2002 @ Sep 29, 2009 - 7:21 PM) *
they aren't great. I replaced one because it had a short somewhere in there that kept blowing a fuse that would cause the car to not start. A lot of the loom is removed, though I think I did find the short in one of the injector wires pinched below my valve cover.
The other one I used to repair another harness and has about 3-4 of the wires/connectors removed. I believe it's just for the o2 sensors, and I think one that ran from the fuse box to the positive battery terminal.
If you want either I'd let them go for cheap, but they are kinda heavy so shipping might be around $15-20. PM me if you're interested. I'll get pics of both harnesses and the intake tomorrow morning.
post Sep 30, 2009 - 11:45 AM
6strngs
Joined May 12, '06
From Wilmington, NC
And pics. Harness one, has about 4-5 connectors missing and a few wires like I said. This one is Federal spec:
And harness 2, The only missing connectors are for the oil pressure and one for the A/C blower I think. Also maybe the VSV for fuel pressure connector (this is only on california spec cars though) This harness is california spec:
I'll take $45 shipped for one or $65 shipped for both.
And here's the intake. The blue coupler on it is ripped and is garbage, and the filter looks like a K&N, but is just a cheapy from kragen/autozone. I can include the filter if you want it or not, your choice. It has a nipple welded on for your PCV line. This intake could maybe also work for a 3sgte if you shortened it enough to fit the MAF in there (or if your running a 3rd gen or with a standalone w/ MAF delete it might fit as is)
post Sep 30, 2009 - 11:50 AM
6strngs
Joined May 12, '06
From Wilmington, NC
here's a pic of the oil filter relocation kit, the oil pan, and the head and block (not the valve cover, the one I have for sale is un-painted)
Here's a couple of the intake installed on my car:
downpipe:
This post has been edited by 6strngs: Sep 30, 2009 - 11:55 AM
post Oct 2, 2009 - 9:50 PM
payment sent
post Oct 2, 2009 - 10:02 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (njccmd2002 @ Oct 2, 2009 - 7:50 PM) *
payment sent
Harness #2 sold. And mailed out, I'll send you the tracking number via PM
post Oct 8, 2009 - 7:52 PM
6strngs
Joined May 12, '06
From Wilmington, NC
bump
post Oct 10, 2009 - 3:21 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Hey, I was wondering if your 5sfe head is the same as a 96 5sfe head? Are they interchangeable? What about the blocks? Let me know, thanks!
post Oct 10, 2009 - 9:10 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (MaskedMan @ Oct 10, 2009 - 1:21 AM) *
pretty sure all the ones from 92-97 are the same. 90-91 didn't have a knock sensor, and 98+ have the metal head gasket and all that. You might want to get someone else to confirm this though
post Oct 13, 2009 - 12:38 PM
6strngs
Joined May 12, '06
From Wilmington, NC
pic of valve cover:
post Oct 23, 2009 - 2:31 PM
6strngs
Joined May 12, '06
From Wilmington, NC
Oil filter relocation kit sold!
Buy this stuff guys or I might just take it to a metal scrapyard to get a few bucks for it.
post Nov 3, 2009 - 3:43 PM
6strngs
Joined May 12, '06
From Wilmington, NC
Downpipe sold.
Valve cover pending.
post Nov 3, 2009 - 5:14 PM
FunkySR
Joined Apr 22, '07
From Buckinghamshire, UK
hey u got a pic of the T Piece?
post Nov 4, 2009 - 3:49 AM
6strngs
Joined May 12, '06
From Wilmington, NC
will get one tomorrow
Lo-Fi Version Time is now: April 21st, 2025 - 2:53 AM
