> Lots of things going wrong... Popped fuse?, Bleh
post Oct 5, 2009 - 6:04 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
So I decided to get brighter lights for my backup lights today because they looked more yellow than anything.. So I bought some superwhite lights.
I put one in to compare, and it looked good. So then I put them in both. I threw it into reverse, and the lights didn't work. I turned my car on, and the tach, speedometer, and temperature gauge don't work, either. I called my friend and he said it sounds like a popped fuse... But I took them out and checked them and they look fine.
I also put the normal bulbs back in to see if that did anything, same problem.
Turn signals, front lights, break lights, all that stuff works fine.
1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver
post Oct 5, 2009 - 6:28 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Well you did pop a fuse. I'll have to look and see what the specific name is, but I had this problem when I put my Omori's in my WRX. Assuming the same sort of thing applies, since wiring is wiring and fuses are fuses.
Dome lights and door lights working?
**** Photobucket
post Oct 5, 2009 - 6:29 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
Yup. They work fine.
post Oct 5, 2009 - 8:08 PM
richee3
Joined Jun 29, '08
From Denver
Every once in a while, a fuse won't look blown even though it is. Figure out which fuse is for your reverse lights, and replace that anyway and see where that gets you. It can't hurt anything.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 5, 2009 - 8:19 PM
zfjohnson07
Joined Apr 11, '09
yeah i had that problem as well with the car before my celica the fuse was cracked barely and you'd have to put it under a microscope to see it, you might as well try to replace all the fuses, wouldnt hurt to check eh?
post Oct 5, 2009 - 9:00 PM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
check your GAUGE FUSE.
post Oct 5, 2009 - 9:33 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
QUOTE (vile_v @ Oct 5, 2009 - 10:00 PM) *
Replaced and it works fine now. It didn't look blown at all.
Thanks guys!
post Oct 5, 2009 - 9:34 PM
I said that in the chat room !
post Oct 15, 2009 - 7:15 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
quick question did you plug in the dimmer switch
[img=http://img56.imageshack.us/my.php?image=signature2fs0.jpg]
Lo-Fi Version Time is now: December 2nd, 2024 - 12:40 PM
