Flush Fit Wheel Fitment, Offsets for Flush Fitment which is Proper Fitment |
Jan 13, 2012 - 10:02 PM |
Enthusiast Joined May 4, '09 From coral springs florida US Currently Offline Reputation: 21 (100%) |
hello im planning one getting a extra set of rims. they are xxr522 18x9.5 ET38 and im planning to use 225/40 tires which is not too strech. ill be pretty flush and ill keep my same stance. just wanted to share this. some examples-->
all pics are 18x9.5 ET38 using 225/40 tires This post has been edited by diegohiga: Jan 13, 2012 - 10:03 PM -------------------- |
Jan 13, 2012 - 11:53 PM |
Enthusiast Joined Dec 11, '07 From Davie, Florida Currently Offline Reputation: 4 (100%) |
Not 100% but I believe 225 series tires would be a lot more stretched than what is showed in that pic. I may be wrong, but when I had 9.5's on my Celi, I had 255 & it looked about what is shown in the pic you posted. If not, than more stretched. I'm just going by what I had on my car. They were Bridgestones 255/35/18 on 18x9.5's.
-Hope I helped, Ryan |
Jan 14, 2012 - 2:54 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
+38 is different between every car, you know that right??
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jan 14, 2012 - 1:01 PM |
Enthusiast Joined Feb 27, '11 From trevorton pa Currently Offline Reputation: 0 (0%) |
This post has been edited by TRD11: Jan 14, 2012 - 1:11 PM -------------------- cant stop wont stop
Jan 14, 2012 - 9:56 PM |
+38 is different between every car, you know that right?? Haha of course. I just got those pics to show the wheels and how strech the tires would be. And yes they are 225/40 -------------------- |
Jan 23, 2012 - 7:46 PM |
Enthusiast Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) |
Not 100% but I believe 225 series tires would be a lot more stretched than what is showed in that pic. I may be wrong, but when I had 9.5's on my Celi, I had 255 & it looked about what is shown in the pic you posted. If not, than more stretched. I'm just going by what I had on my car. They were Bridgestones 255/35/18 on 18x9.5's. -Hope I helped, Ryan How did you get 9.5in wheels with 255 tires on our car? I want either 245 or 255's on my Gt-Four with atleast 9in wheels. Is it doable? My goal is to have barely streched tires with a flush look, what do I need? |
Jan 28, 2012 - 1:54 AM |
Enthusiast Joined Nov 17, '11 From Esko, MN Currently Offline Reputation: 0 (0%) |
Just got a set of TC rims for my celica and see someone recommends 225/45 tires. Want to do an eibach sport drop, what size spacer do I need w the drop to make the car look nice? Hella flush not necessary. Thanks for the help!!
Jan 29, 2012 - 6:55 PM |
Enthusiast Joined Oct 26, '04 From minnesota, oakdale Currently Offline Reputation: 0 (0%) |
I just found out my passenger side 7th gen wheels are slightly bent so I'll be in the market for a new set of wheels and rubber. A buddy of mines has a set of konig's laying around that i might pick up and use. They are 17x7 with a 42 offset, i'm dropped with tein springs, what size tires and spacers would I be looking at getting if I want to have clean look!?
-------------------- my long awaited celica,
Jan 29, 2012 - 11:18 PM |
Enthusiast Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
About a 25mm.
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Jan 30, 2012 - 2:06 PM |
are my calulations correct?
rims: 17x7 with a 42 offset front: 42-10: 32mm rear: 42+8: 50mm dam, if it's right then i don't see the rims working... better luck spending my money on another set. -------------------- my long awaited celica,
Jan 30, 2012 - 2:43 PM |
are my calulations correct? rims: 17x7 with a 42 offset front: 42-10: 32mm rear: 42+8: 50mm dam, if it's right then i don't see the rims working... better luck spending my money on another set. You would be better off with wider if that is what you are going for. My current wheels are unfortunately similair dimensions (17x7 +40) and i run a 25mm spacer up front and 30mm in the rear. I was just giving you the 25mm figure as an upgrade from the sunken battleship look. Not hellaflush by any means but with coilovers it still looks pretty good. Of course, we all want wider wheels dont we... -------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
Jan 30, 2012 - 9:29 PM |
I see. Thanks for the info. I'm not planning on going for a hellaflush look but just a flusher look. Wider would be nice but I'm pretty much getting the rims free so i can't complain. Just wanted to make sure they would work.
Jan 31, 2012 - 8:06 AM |
Not 100% but I believe 225 series tires would be a lot more stretched than what is showed in that pic. I may be wrong, but when I had 9.5's on my Celi, I had 255 & it looked about what is shown in the pic you posted. If not, than more stretched. I'm just going by what I had on my car. They were Bridgestones 255/35/18 on 18x9.5's. -Hope I helped, Ryan How did you get 9.5in wheels with 255 tires on our car? I want either 245 or 255's on my Gt-Four with atleast 9in wheels. Is it doable? My goal is to have barely streched tires with a flush look, what do I need? A LOT OF WORK my friend! Just kidding, it's doable. But are you willing to work for it? Rolled the crap out of my fenders & used spacers as well. The rolling process is kind of a drag. Since you're going with such a wide wheel, a lot of trial & errors go on. Well, at least for me it did. I rolled fender, put wheel back on, drove around to check for clearance & what not, then came back & started process all over until I got it how I wanted. I forgot the exact size of spacer I used, but if you really want to know I can try & find out for you. With 9" you shouldn't have too much of a problem in the rear, the fronts MIGHT need some modifications for you to fit with no rubbing issues. Just follow Harold's specs & you should be good. He does a lot of research for this site for your use, so take advantage & don't forget to say thank you. Lol. -Ryan are my calulations correct? rims: 17x7 with a 42 offset front: 42-10: 32mm rear: 42+8: 50mm dam, if it's right then i don't see the rims working... better luck spending my money on another set. You would be better off with wider if that is what you are going for. My current wheels are unfortunately similair dimensions (17x7 +40) and i run a 25mm spacer up front and 30mm in the rear. I was just giving you the 25mm figure as an upgrade from the sunken battleship look. Not hellaflush by any means but with coilovers it still looks pretty good. Of course, we all want wider wheels dont we... :] YEAAAA! Wider wheels = better traction! = better handling as well! GO FOR IT! -Ryan |
Jan 31, 2012 - 10:36 PM |
Not 100% but I believe 225 series tires would be a lot more stretched than what is showed in that pic. I may be wrong, but when I had 9.5's on my Celi, I had 255 & it looked about what is shown in the pic you posted. If not, than more stretched. I'm just going by what I had on my car. They were Bridgestones 255/35/18 on 18x9.5's. -Hope I helped, Ryan How did you get 9.5in wheels with 255 tires on our car? I want either 245 or 255's on my Gt-Four with atleast 9in wheels. Is it doable? My goal is to have barely streched tires with a flush look, what do I need? A LOT OF WORK my friend! Just kidding, it's doable. But are you willing to work for it? Rolled the crap out of my fenders & used spacers as well. The rolling process is kind of a drag. Since you're going with such a wide wheel, a lot of trial & errors go on. Well, at least for me it did. I rolled fender, put wheel back on, drove around to check for clearance & what not, then came back & started process all over until I got it how I wanted. I forgot the exact size of spacer I used, but if you really want to know I can try & find out for you. With 9" you shouldn't have too much of a problem in the rear, the fronts MIGHT need some modifications for you to fit with no rubbing issues. Just follow Harold's specs & you should be good. He does a lot of research for this site for your use, so take advantage & don't forget to say thank you. Lol. -Ryan Thanks man. Would you happen to know a site or somewhere I can find out how tires look on wheels E.g. I'd like to see how 245s/255s look on 9/9.5in wheels. |
Feb 1, 2012 - 3:31 AM |
Enthusiast Joined Apr 17, '10 From Maitland, NSW Currently Offline Reputation: 3 (100%) |
Feb 1, 2012 - 11:02 PM |
THANK YOU SO MUCH SIR. This is exactly the site I was looking for haha Now I know I'll be going with either 9.5 or 10in wide wheels ^^ This post has been edited by dudeofchaos: Feb 1, 2012 - 11:10 PM |
Feb 3, 2012 - 1:33 PM |
Enthusiast Joined Oct 28, '09 From North East, UK. Currently Offline Reputation: 0 (0%) |
Mine at the mo, please excuse the fact the car hasn't been washed!
17x8 rims, running 225/45/17 and et15 up front, et5 rear with 3 degrees neg camber on the rear, 1.5 on the front. This post has been edited by Rob_A: Feb 3, 2012 - 1:35 PM -------------------- |
Mar 2, 2012 - 3:41 PM |
Enthusiast Joined Nov 23, '11 From Tampa, FL Currently Offline Reputation: 0 (0%) |
Hey I purchased a a set of rims for cheap.. lkq is my best friend haha, I found a set of drag dr-19s real nice they are 5x100 with offset of 45 I believe. I haven't tried put them on my. Car yet. But reading this thread it made me wonder.... Wat all will I need for it to slide in my car. Would I need spacer? If so what should I go with. My celi. Has been lowered. About 2in on some eibach springs.
Mar 2, 2012 - 3:55 PM |
^ They'll fit right on.
'93 MX-5 LE |
Mar 2, 2012 - 4:22 PM |
Sweet so I won't need spacers or anything nor have worry about anything?
Lo-Fi Version | Time is now: November 29th, 2024 - 10:37 PM |
