19 Pages V  « < 12 13 14 15 16 > »
> Flush Fit Wheel Fitment, Offsets for Flush Fitment which is Proper Fitment
post Jun 15, 2012 - 9:06 PM
Ehrgeiz
Joined May 23, '11
From The Netherlands
post Jun 15, 2012 - 9:08 PM
Lil-Joe101
Joined Dec 7, '07
From Corpus Christi, TX
Toilets clogged, still got more flushin ta do, lol
215/40/R17
post Jun 16, 2012 - 5:30 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
17x8 et23 with -1 deg camber and guards rolled, 225/45/17 seems to be the magic numbers for my st205 with bc coilovers
Mike W
269awhp / 273ft-lbs
post Jun 25, 2012 - 7:01 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
Anyone ran 9.5" on a 6th gen? pics? modds required?
My guards have already been lipped and rolled years ago, and yes I have suspension work and currently neg 3 camber.
I'm looking to get some wheels, and I'm tossing up between 18x8.5 and 18x9.5 all round, wheel make and model will remain a secret but they are the only two widths available and the offsets available are
18x8.5 are: +45 +38, +30mm
18x9.5 are +12, +20, +30 +38mm
cheers.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Jun 25, 2012 - 8:14 PM
hzawde
Joined Nov 13, '10
From Calgary
im thinkin of getting some xxr 530s for my st205, will 17X7 5x100/5x114.3 et35 fit ??
and what tires should i get
thanks
post Jun 26, 2012 - 5:41 AM
Ehrgeiz
Joined May 23, '11
They'll fit.. But I recommend going a little wider if I were you. Just for the extra beef. smile.gif
post Jun 27, 2012 - 12:38 AM
diegohiga
Joined May 4, '09
From coral springs florida US
Yes go wider like 17x8 (225/45/17 tires) or 17x8.5 (235/45/17 tires) leave the 7 wide for scooters.
Another option 18x8 (225/40/18 tires) or 18x8.5 (235/40/18 tires)
Offset 35 is perfect dont get a higher offset than 35.
This post has been edited by diegohiga: Jun 27, 2012 - 12:44 AM
post Jun 27, 2012 - 8:38 AM
hzawde
Joined Nov 13, '10
From Calgary
ok well these are my options right now
XXR 530 17x8.25 Flat Black 5-100/5-114.3 [+25mm]
XXR 530 17x8.25 Flat Black 5-100/5-114.3 [+35mm]
XXR 530 17x7 Flat Black 5-100/5-114.3 [+35mm]
XXR 530 17x9.75 Flat Black 4-100/4-114.3 [+25mm]
post Jun 27, 2012 - 9:05 AM
diegohiga
Joined May 4, '09
QUOTE (hzawde @ Jun 27, 2012 - 9:38 AM) *
17x7 not wide enough
17x9.75 too big and offset too high. Front wheels will stick out and our cars are 5x100 not 4x100/4x114.3
I would go with the 17x8.25 +35 or 17x8.25 +25 both will fit fine but the +25 will be more flush to the fenders.
post Jun 27, 2012 - 1:49 PM
Ehrgeiz
Joined May 23, '11
Would you consider 18's? Because the 530's are available in 18x8,75 +35 for the front (might need a small spacer), and 18x8,75 +20 for the rear. That would look great.
post Jun 27, 2012 - 6:13 PM
hzawde
Joined Nov 13, '10
From Calgary
alright thanks everyone, i thinkk ill stick with the 17s so which tires should i get ? for 17x8.25 25offset
post Jun 27, 2012 - 6:30 PM
diegohiga
Joined May 4, '09
QUOTE (hzawde @ Jun 27, 2012 - 7:13 PM) *
225 would be just a little streched but looks good or 235/45/17
post Aug 2, 2012 - 3:16 PM
veadp
Joined Jul 31, '12
From Ajax, ON
Just a quick question...
Can a 17x7.5 - ET42 fit on a ST205?
I am thinking of using 225/45/17 Tires.
I want a Flush look, so what would be required?
post Aug 2, 2012 - 3:52 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
et42 will be very sunken in. 25mm spacers in the front would make it flush but for the rear you'd need around 30mm+ or so
This post has been edited by Tigawoods: Aug 2, 2012 - 3:52 PM
エキサイティングカーレーシングチーム!
post Aug 2, 2012 - 8:09 PM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
much better going with 17x8 et35, there are lots available. then if you want flush you could do 10 mm spacer front and 25 mm rear.
post Aug 3, 2012 - 10:32 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
QUOTE (Promasta @ Aug 2, 2012 - 8:09 PM) *
x2 This is really one of the best options for us, unless you want to make the change to 5x114.3. Then the mother lode of width and offset combinations shall be unlocked.
June '12 COTM
'95 AT200
post Aug 3, 2012 - 2:07 PM
yellowchinaman
Joined Aug 11, '08
From London
Question!
Does anyone know the depth difference between the front and rear on a stock Gen 6?
post Aug 4, 2012 - 8:24 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
my best guess is 10mm
エキサイティングカーレーシングチーム!
post Aug 4, 2012 - 8:39 AM
WhipCreamCelica
Joined Feb 1, '12
From The Colony, TX
Hectors right! I test fitted my friends xxr 521s the other day. he's 5x114.3 so it didn't fit. but we put itvas close to the studs as possible and slowly lowered the car. didn't go all the way down since the car was on the tire. but these were 18x10.5 in the rear with crazy low offset. wish I was 5x114.3 so I could buy them.
but I would have run crazy negative camber so I could actually be as low as I am right now
post Aug 4, 2012 - 3:25 PM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (Tigawoods @ Aug 4, 2012 - 9:24 AM) *
Can someone confirm this?
Basically if you have had a set of wheels front and rears with different offsets and they both fit perfectly then I want to know the difference.
eg:
Front ET 25 and Rear ET 40 so difference it 15mm.
edit
First post just confirmed it.
at 6.5 wide,
front is 0
rear is 15
so difference is 15mm.
Now whats the best way to space the rears for 15mm? Use studed spacers? Then the nuts won't sit deep enough and will obstruct the alloy?
Hammer out the studs and use longer ones and have a 15 spacer? Can I do that without removing the hub?
This post has been edited by yellowchinaman: Aug 4, 2012 - 3:29 PM
Lo-Fi Version Time is now: November 29th, 2024 - 10:39 PM
