19 Pages V  < 1 2 3 4 5 > »
> Flush Fit Wheel Fitment, Offsets for Flush Fitment which is Proper Fitment
post Mar 4, 2010 - 5:19 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
With fiberglass fenders you're going to need to worry about the wheels hitting and cracking them. I would highly suggest going back to OEM and then roll the fender lip flat.
Look for Eibach's camber kit. They'll do what you need.
**** Photobucket
post Mar 4, 2010 - 10:56 PM
nintyfourcelicam...
Joined Jan 13, '10
From CT, USA
thank you for the link and the advice!!! i will let you know how i make out with it all.... i really do appriciate it! thanks again
post Mar 12, 2010 - 6:03 AM
Goonter
Joined Nov 27, '09
From Canada
k i'm planning on using spacers/adapters. but have a few questions before a go ahead and do it. safety-wise, which one is better. 15 mm spacers with extended studs, or a 25 mm Bolt-on Adapter? and how fast will each setting eat up my wheel bearing frown.gif?
post Mar 13, 2010 - 12:02 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
both eat up your bearings at the same rate. It will depend on your final offset to give you an overall amount. Not like we can tell you an exact time frame they will last anyway. All depends on your mileage to begin with.
I dunno which is better between bolt on or studs. I wouldnt trust 15mm with extended studs though, but I bet science can prove me wrong. I just think anything over 10 needs to be bolted on.
post Mar 13, 2010 - 12:21 AM
Goonter
Joined Nov 27, '09
From Canada
arg .. i see thanks for the response. guess ill try out 25mm bolt-ons on rear and 10 mm extended stud in the front. anywho. how much would it be for new wheel bearings each?.. just so i know how much i would be spending in case they DO give out
post Mar 13, 2010 - 5:14 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE (Goonter @ Mar 13, 2010 - 12:21 AM) *
go to RockAuto.com and look them up. They give you a pretty solid price, they will be comparable if you go to Autozone or Advance Auto as well.
post Mar 13, 2010 - 6:41 PM
Goonter
Joined Nov 27, '09
From Canada
post May 2, 2010 - 6:19 AM
whatthe
Joined Aug 13, '08
From Australia
Throwing my 17x8 +35 with 225/45/17 this week back on. With a set of these 25mm 56mm bore hub centric spacers effectively making the rear +10. I probably wont be able to run these straight up as it will rub with the rear lining and need to get it rolled somewhere. But im looking forward to it biggrin.gif
This post has been edited by whatthe: May 2, 2010 - 6:19 AM
post May 2, 2010 - 11:47 AM
Driveby
Joined Sep 17, '05
From Newcastle / UK
Snap! (almost)
Just fitted 30mm H&R rear spacers and 10mm fronts on the same size wheel and tyre combo on my GT4.
No rubbing issues with my suspension set up, but I have camber bolts on the rear to improve my stance woot.gif
1994 JDM GT4 WRC
post May 2, 2010 - 12:04 PM
whatthe
Joined Aug 13, '08
From Australia
Driveby how much negative camber are you running on the rear? You didnt have the roll guards? From what i remember with my 17x8 on it was cutting close the the lining without spacers.
post May 2, 2010 - 12:19 PM
Driveby
Joined Sep 17, '05
From Newcastle / UK
I dont know the exact reading mate, I set it up with a spirit level (to get both sides equal) and how it looked. I have coilover rear suspension set for track use so is very firm, I am planning on rolling my rear arches as Im on a quest for moar low although I dont need to with my current set up. Maybe the 202 and 205 rear suspension setups are quite different, Im not sure. The tops of my rims are flush with the outer arch and I can get 1 finger between the top of the tyre and the arch. The bottom of the strut is only 3mm from the rear cv boot so I darent go any lower on this setup
Im at a 2litre turbo shoot-out tomorrow so will hopefully get some good pics and will post them up for approval.
Hope this helps mate.
1994 JDM GT4 WRC
post May 3, 2010 - 1:07 PM
Driveby
Joined Sep 17, '05
From Newcastle / UK
By looking at the pictures Im running a bit of negative camber in the rear wink.gif Ill have to measure it at work.
1994 JDM GT4 WRC
post May 4, 2010 - 5:54 AM
vincent_doggy
Joined May 25, '06
From Hong Kong
Guys do some math for me, I have 17x7.5 offset30 all around
No need to be hella flush, just more flush...
Please provide 2 data for the rear if possible:
Roll fender & No Roll
Thanks!
post May 20, 2010 - 4:55 AM
whatthe
Joined Aug 13, '08
From Australia
VC you will need 15mm on the front and 30 at the back. These are both for roll. I guess if you dont want to roll buy like 10 and 25?
post May 28, 2010 - 5:06 AM
whatthe
Joined Aug 13, '08
From Australia
Okay 6gc, i have a serious dilemma.
My 15mm bolt on spacers need some serious work on the wheels to get it to work. At the moment they are at the tyre shop waiting for monday to get the back to get shaved abit so the stud and nut that sticks out of the spacer wont get in the way.
Shaving the back in futher would cost like $145 which is basically what the spacers cost. And then i will need shorter studs for the hub.
I was thinking this will be all over if i ran 20mm spacers at the fronts. Cause the nut and stud wont be sticking out.
But that would make my fronts 17x8 +15. I dont know if that is too much poke.
post May 28, 2010 - 1:05 PM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
marco has 18x8 +15 front and rear, and it looks amazing. but with that aggressive of an offset your 225/45 tires are too wide. with any poke you want a stretched tire, at least 215/45 or 215/40.
post May 28, 2010 - 1:39 PM
whatthe
Joined Aug 13, '08
From Australia
^ Thanks for that. Marcos running 225 anyway and it looks decent. Either way going to purchase 20mm tomorrow, and hopefully solves all my problems and then pick up rims back from the wheel shop on monday. Alll that running around today in town all for nothing!
post May 30, 2010 - 3:38 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
post May 30, 2010 - 5:12 AM
whatthe
Joined Aug 13, '08
From Australia
^Dude how big are they?
post Jun 1, 2010 - 4:16 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
1.5" converted into mm???
Lo-Fi Version Time is now: November 26th, 2024 - 6:26 PM
