One acronym... BEAMS |
Mar 5, 2010 - 10:12 PM |
Enthusiast Joined Aug 29, '07 From San Diego Currently Offline Reputation: 0 (0%) |
FINALLY THE LAST PART NEEDED TO CONTINUE THE SWAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I HOPE...
Mar 10, 2010 - 2:50 AM |
update
Mar 12, 2010 - 1:21 PM |
Enthusiast Joined Apr 24, '07 From CA Currently Offline Reputation: 1 (100%) |
Idk if you covered this already, but what are you going to do about smog and stuff once its all finished up?
-------------------- QUOTE what hes saying is if you put blue lights in you car youll lose hp. |
Mar 12, 2010 - 9:49 PM |
I'm procrastinating cuz i'm in the middle of moving so as soon as I move or have a day off then I'll continue the work...
Jun 1, 2010 - 10:43 AM |
Well the swap is done but the car overheats and spills the coolant...any ideas?
Jun 1, 2010 - 11:52 AM |
spills the coolant ? how does it spill ?and where ?
Jun 1, 2010 - 12:10 PM |
I would guess bad water pump ? same thing happened to my friend's Camry, he called me after the car died, when I arrived there was a big puddle of coolant on the floor, after some inspection, water pump was gone, we replaced it and done. the car has been running like a champ.
Jun 1, 2010 - 5:40 PM |
Jun 1, 2010 - 6:52 PM |
Enthusiast Joined Aug 24, '09 From San Diego, Ca Currently Offline Reputation: 0 (0%) |
spills the coolant ? how does it spill ?and where ? i couldn't tell for sure but its right behind or above the tranny. dont know what hose it is. I'm pretty sure that it wasn't the water pump because it was checked when the timing belt was replaced... Well I havent worked on a beams before, do they have water cooled intakes or not? Also, if the engine sat for a long time out of a car it's possible the head gasket is corroded around the cooling ports, I've seen this happen and coolant will puke out of that area. Edit: I would 1st pressure test the system and see if you can figure out where the coolant is coming from while the engine is cold.. Don't run it till you figure it out, last thing you want is to have to rebuild a Beams thats been badly damaged, I hear that gets expensive fast. This post has been edited by Jamchell: Jun 1, 2010 - 7:02 PM |
Jun 1, 2010 - 7:39 PM |
there are hoses that go to the intake. check those. put pics.
Jun 1, 2010 - 10:08 PM |
there are 2 water hose back there.
One connects to the firewall and the other to the recirc valve on the firewall, one or both is leaking. -------------------- |
Jun 4, 2010 - 12:56 AM |
Lo-Fi Version | Time is now: December 3rd, 2024 - 6:36 AM |
