One acronym... BEAMS |
Oct 21, 2009 - 11:39 AM |
Enthusiast Joined Aug 29, '07 From San Diego Currently Offline Reputation: 0 (0%) |
do u really need to blow 200 bucks on an hks timing belt??? im sure and oem one will work just the same?? prolly alot cheaper too well I don't know but I bet the HKS timing belt is stronger, supposedly its made of kevlar whereas the OEM is probably just rubber... |
Oct 21, 2009 - 11:38 PM |
Its here!!!!!!!!!!
going in here: This post has been edited by erahman85: Oct 22, 2009 - 2:01 PM |
Oct 23, 2009 - 2:59 PM |
I asked a mechanic to quote me on how much it would be to do the swap and he told me he didn't want to do it cuz it was too much work lol. How much more do you have to do compared to a straight swap with another 5sfe????? Anyone out there interested in doin a swap????
Oct 23, 2009 - 3:51 PM |
Enthusiast Joined Aug 24, '09 Currently Offline Reputation: 1 (100%) |
Congrats. If you where in MD I would offer to help. Good Luck and just be sure to have a lot of bolt containers and label them and your job will be much easier putting it back together.
Oct 23, 2009 - 7:36 PM |
congrats mang
Oct 23, 2009 - 10:07 PM |
dude, even with the stock airbox, i envy you, check all sensors, to be there, vvti, tps, vacuum, o2, and that they are not broken
Oct 23, 2009 - 10:34 PM |
Oct 24, 2009 - 9:13 AM |
I asked a mechanic to quote me on how much it would be to do the swap and he told me he didn't want to do it cuz it was too much work lol. How much more do you have to do compared to a straight swap with another 5sfe????? Anyone out there interested in doin a swap???? as far as removing the old motor, and installing the new one, they are exactly the same. figuring out how to get the beams harness thru the firewall, and doing the wiring are the only diffrences. everything mounts up the same way, in the same locations, as far as the motors are concerned. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Oct 24, 2009 - 6:21 PM |
I asked a mechanic to quote me on how much it would be to do the swap and he told me he didn't want to do it cuz it was too much work lol. How much more do you have to do compared to a straight swap with another 5sfe????? Anyone out there interested in doin a swap???? as far as removing the old motor, and installing the new one, they are exactly the same. figuring out how to get the beams harness thru the firewall, and doing the wiring are the only diffrences. everything mounts up the same way, in the same locations, as far as the motors are concerned. So the A/C lines are all in the same place and the power steering stuff too? The mechanic was more concerned about the vac lines or something like that, do those have to be replaced? |
Oct 25, 2009 - 8:00 AM |
I asked a mechanic to quote me on how much it would be to do the swap and he told me he didn't want to do it cuz it was too much work lol. How much more do you have to do compared to a straight swap with another 5sfe????? Anyone out there interested in doin a swap???? as far as removing the old motor, and installing the new one, they are exactly the same. figuring out how to get the beams harness thru the firewall, and doing the wiring are the only diffrences. everything mounts up the same way, in the same locations, as far as the motors are concerned. So the A/C lines are all in the same place and the power steering stuff too? The mechanic was more concerned about the vac lines or something like that, do those have to be replaced? the gt ac lines bolted up on dustin and steffs car, as well as the power steering. the only vac lines that go from motor to chassis are the brake booster, and the charcole canister. your mechanic is being shyed away by the fact you wanna install a motor that he has never seen or prolly heard of. most normal, everyday mechanics would say the same things. i never, ever recommend having a normal mechanic do these kind of motor swaps, it almost always turns out bad in one way or another. -------------------- Former Team 5SFTE pro member ;)
Oct 26, 2009 - 9:55 AM |
the only vac lines that go from motor to chassis are the brake booster, and the charcole canister. your mechanic is being shyed away by the fact you wanna install a motor that he has never seen or prolly heard of. most normal, everyday mechanics would say the same things. i never, ever recommend having a normal mechanic do these kind of motor swaps, it almost always turns out bad in one way or another. [/quote] YEah the mechanic is my dad's friend, he's supposedly put a toyota engine in a ford truck and other crazy stuff but he just said he is too old to be doing swaps lol He told me I could do it and learn but it would take time. I have no experience in anything other than changing breaks and doing tune-ups. I can't figure out how to install the clutch master cyl. though because there are no markings on the firewall and the sticky in this forum is missing the pictures. I think I'll start with the auto to Manual conversion first does that sound like a good idea? This post has been edited by erahman85: Oct 26, 2009 - 9:55 AM |
Oct 26, 2009 - 1:39 PM |
yup
Oct 27, 2009 - 5:35 PM |
Here's what I did today since I got a flat tire and couldn't make it to work...
The shifter has a bunch of connections that I don't know what they do... Getting this out was a pain in the @! This is the stereo amp. and the ABS thingy auto to manual swap! got the break pedal done! this was a piece of cake! all you have to do is remove 1 bolt and a pin then install the new pedal, put the pin and bolt back in and thats it! Installing the clutch will be super easy as well cuz everything is already marked! This is where the clutch master cyl goes. and this is where the pedal assembly is bolted to as well, notice the gray screw already in place. |
Oct 31, 2009 - 8:28 PM |
Pretty much done with manual conversion...
Oct 31, 2009 - 8:32 PM |
Wow, awesome. How experienced are you with cars, and how hard would you say it was to do? And we need pics of the finished product!
'93 MX-5 LE |
Nov 1, 2009 - 12:24 AM |
Wow, awesome. How experienced are you with cars, and how hard would you say it was to do? And we need pics of the finished product! It was really easy, I thought it was going to be harder but its not. I still have some minor details to clean up so that it looks better (i need a rubber washer for the clutch master cyl.) and then I'll post pictures... I have no experience at all with major mechanical work! I totally did not know what I was doing but its pretty self explanatory once you get down to it! I don't have a lot of tools either just a 69 piece tool set from home depot, a drill (only for the holes in the firewall) and a jack and jackstands and that was it. So yeah anyone can do it. I'll post pics when i get a chance. |
Nov 1, 2009 - 12:55 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
nice, a step closer now
I can understand though, once you pull all the trim off all the loom etc. the manual tranny in yet? hope shes shifting nice. -------------------- |
Nov 1, 2009 - 7:28 AM |
Wow, awesome. How experienced are you with cars, and how hard would you say it was to do? And we need pics of the finished product! It was really easy, I thought it was going to be harder but its not. I still have some minor details to clean up so that it looks better (i need a rubber washer for the clutch master cyl.) and then I'll post pictures... I have no experience at all with major mechanical work! I totally did not know what I was doing but its pretty self explanatory once you get down to it! I don't have a lot of tools either just a 69 piece tool set from home depot, a drill (only for the holes in the firewall) and a jack and jackstands and that was it. So yeah anyone can do it. I'll post pics when i get a chance. thats awesome, congrats! the auto to manual conversion really is not that big a deal at all once you get in and working on it. good to see everything moving along. -------------------- Former Team 5SFTE pro member ;)
Nov 1, 2009 - 11:57 AM |
Hey I was looking at the two different face gauges and the ones that I have to swap for the BEAMS conversion (Tach) fits in the GT face gauge perfectly but if you look at the circuit board there are some major differences. Does anyone know if all I have to do is swap the tach straight out and thats it or do I have to do anything else?
this is the BEAMS Face gauge: this is the Celica GT face gauge: |
Nov 1, 2009 - 12:43 PM |
the tach and fuel is supposed to be a straight swap. the wiring is easy, i just made it look complicate lol. but is really not.
you need to get a engine crane and voila. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Lo-Fi Version | Time is now: December 2nd, 2024 - 8:01 AM |
