7 Pages V  « < 2 3 4 5 6 > »
> One acronym... BEAMS
post Nov 1, 2009 - 12:45 PM
erahman85
Joined Aug 29, '07
From San Diego
QUOTE (njccmd2002 @ Nov 1, 2009 - 12:43 PM) *
the tach and fuel is supposed to be a straight swap. the wiring is easy, i just made it look complicate lol. but is really not.
you need to get a engine crane and voila.
well I just did the straight swap and I hope it works. Yeah the harness looks insane lol...
post Nov 1, 2009 - 2:52 PM
QUOTE (erahman85 @ Nov 1, 2009 - 1:24 AM) *
It was really easy, I thought it was going to be harder but its not. I still have some minor details to clean up so that it looks better (i need a rubber washer for the clutch master cyl.) and then I'll post pictures... I have no experience at all with major mechanical work! I totally did not know what I was doing but its pretty self explanatory once you get down to it! I don't have a lot of tools either just a 69 piece tool set from home depot, a drill (only for the holes in the firewall) and a jack and jackstands and that was it. So yeah anyone can do it. I'll post pics when i get a chance.
That's great to hear. I was just wondering if I could attempt this in the future...but honestly, I don't even change my own oil (bad, I know frown.gif).
post Nov 1, 2009 - 4:43 PM
erahman85
Joined Aug 29, '07
From San Diego
QUOTE (SwissFerdi @ Nov 1, 2009 - 3:52 PM) *
Yeah You could do it. I hardly ever change my own oil either cuz its just so cheap to have a shop do it...
post Nov 1, 2009 - 9:42 PM
richee3
Joined Jun 29, '08
From Denver
The shops here all charge $29.99 to change your oil, where I can do it myself for about $16. I can change my oil two times for what the shops charge for it.
So the auto to manual wasn't too hard, eh? That's good to know. You'll have to let us know how you like having a manual!
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 1, 2009 - 10:08 PM
QUOTE (erahman85 @ Nov 1, 2009 - 4:43 PM) *
Well, I originally wanted to but my brother said his friends that do it themselves say it's not worth it after needing to dispose of the oil, etc. I'm sure it's not hard to find a place to dispose it though, I could probably take it to any auto shop that does oil changes themselves.
One question about the manual swap, how exactly do you mount the clutch pedal? I assume there's some kind of space where it would usually mount, but that is left blank in automatic models. Also, how hard was it to install the shifter assembly? I assume again that there are mounting places where things screw in already existing in the car.
This post has been edited by SwissFerdi: Nov 1, 2009 - 10:09 PM
post Nov 2, 2009 - 12:46 AM
trdproven
Joined Aug 2, '05
From Guam
there should be indentation or markings for the clutch pedal assembly. shifter assembly is just 4 bolts and then you tie in the shifter cables to them.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Nov 2, 2009 - 8:54 PM
erahman85
Joined Aug 29, '07
From San Diego
QUOTE (SwissFerdi @ Nov 1, 2009 - 10:08 PM) *
well the shifter assembly is a straight pull out the auto and put in the manual. To swap the cables you have to get underneath the car, unbolt the heatshield (easy, 4 screws) above the cat and remove the old automatic shifter cable. Then put the manual shifter cables in and thats it. The only other thing that I haven't found out yet is exactly where the manual shifter cables are supposed to be routed through. I mean I don't know if they go over the rack n pinion or what. Its hard to explain without pics but yeah. The clutch pedal is really easy as well. The holes are already marked you just have to drill them. Use a 5/8" drill bit and drill three holes where they are marked. The bigger hole you have to find a drill bit big enough or use a small drill bit then use a saws-all and thats it everything should fit perfectly. If you look at my previous pictures you can see a picture of the firewall with the holes marked.
I gots to go cuz my wife is yelling at me to go eat lol.
post Nov 2, 2009 - 9:01 PM
QUOTE (erahman85 @ Nov 2, 2009 - 8:54 PM) *
Thanks for that explanation. How did you jack the car up?
post Nov 3, 2009 - 11:13 AM
erahman85
Joined Aug 29, '07
From San Diego
QUOTE (SwissFerdi @ Nov 2, 2009 - 10:01 PM) *
bought a 3 ton jack and jack stands at home depot for less than $100
post Nov 3, 2009 - 11:58 AM
Okay, that's a doable addition to the rest of the costs. So I guess it is entirely doable at home then, huh? Enticing.
post Nov 3, 2009 - 1:31 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
God made man....
Everything else...
Made in China
post Nov 10, 2009 - 9:56 PM
erahman85
Joined Aug 29, '07
From San Diego
WHo knows if when doing the swap u use the fuse box (next to the battery) from the BEAMS or use the one thats already in the car?
post Nov 10, 2009 - 10:21 PM
turnip
Joined Aug 24, '09
I used the stock fuse box because I did not get one with my engine. Just take a look and see if the fuses are all the same. Im guessing thats SRS will probably be the only one thats might be different. However I have a 94gt and yours is a 99. It could be a little different. But I would start by identifing each fuse. Wire colors will likely all be the same.
post Nov 11, 2009 - 6:40 PM
erahman85
Joined Aug 29, '07
From San Diego
QUOTE (turnip @ Nov 10, 2009 - 11:21 PM) *
Some mods have to be done to the harness though right? I was looking on other posts But I still Don't understand exactly what I have to change...
post Nov 13, 2009 - 5:46 PM
QUOTE (erahman85 @ Oct 15, 2009 - 9:31 PM) *
1998 TOYOTA CELICA (ST202-BLMZF)
Random Parts that I saw might need replacing and other parts I just punched in (From toyodiy.com)
V Belt:
Part # 9936591120
trademotion.com price: $29.46
V Belt2:
Part# 993639076083
trademotion.com price: $4.99
Oil Filter (also for 00-05 Celica GT and 91-94 Camry 4cyl among others):
Part# 9091510001 Superseded by# 90915YZZF2
trademotion.com price: $4.00
Oil Plug:
Part# 9034112012
trademotion.com price: $3.20
Oil Plug Gasket:
Part# 9043012031
trademotion.com price: $0.82
Crankshaft Pulley:
Part# 1340788380
trademotion.com price: $190.13
Timing Belt:
Part# 1356880015
trademotion.com price: $28.31
Camshaft Timing Pulley:
Part# 1352388301
trademotion.com price: $105.32
No1 Chain Tensioner Assembly:
Part# 1354088561
trademotion.com price: $23.12
Cooling System Radiator Hose:
Part# 1657274230
trademotion.com price: $12.37
Clamp/Clip Radiator Outlet:
Part# 9046734004
trademotion.com price: $3.38
Thermostat:
Part# 9091603100
trademotion.com price: $14.05
Spark Plug:
Part# 909190117883
trademotion.com Price: $6.30
Cord Set Coil & Plug:
Part# 9091921577
trademotion.com price: $89.95
Ignition Coil:
Part# 9091902209
trademotion.com price: $70.00
Water Temperature Sender:
Part# 8342016040
trademotion.com price: $18.57
Water Temp Sensor:
Part# 8942216010
trademotion.com price: $46.72
Water Pump from USDM MR2 Turbo (Supposedly Fits):
Part# 1610079126
trademotion.com price: $112.78
Ok I'm tired...I couldn't find O2 Senso or Exhaust Sensor...Maybe someone could add and remove so we could just get a list of parts that should be replaced for maintenance during a swap.
im ordering based on this part numbers, so ill blame you LOL.
i might get a trd shifter too... hope they have it it is listed at 110 bucks....
post Nov 15, 2009 - 12:23 AM
erahman85
Joined Aug 29, '07
From San Diego
QUOTE (njccmd2002 @ Nov 13, 2009 - 5:46 PM) *
V Belt:
Part # 9936591120
EDIT
I looked for that TRD shifter and my dealership doesn't have it in stock they said its discontinued and they sold out. do you have a part number for it cuz I lost the part number?????
This post has been edited by erahman85: Nov 15, 2009 - 12:24 AM
post Nov 15, 2009 - 2:37 AM
Rusty
Joined Nov 5, '07
From New Zealand
which TRD shifter? TRD ST20X one?
post Nov 15, 2009 - 2:58 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
here's the part number of the version 2
PTR04-20940-04
i know a guy from ebay who can sell one. he quoted me $116 + $7 shipping. he's local but wouldnt allow pick up.
his ebay username/store is garrickwholesale760, contact him and see if he could get hold of it.
hope this helps
God made man....
Everything else...
Made in China
post Nov 15, 2009 - 11:04 PM
iwas going to place an order for the shifter but i just learned its discontinued.
post Nov 16, 2009 - 5:05 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
ill try to get a hold of him, ill check if he has some left over
God made man....
Everything else...
Made in China
Lo-Fi Version Time is now: December 2nd, 2024 - 10:30 AM
