> brake pedal turns radio off, then back on., any suggestions??
post Oct 11, 2009 - 1:52 PM
Badkarma
Joined Apr 23, '06
From Rochester, NY
kinda weird. i was driving along, and i let off the gas pressed the brake pedal and my radio turned off then came back on. i dont think its the physical changing of the momentum because it happen while stopped. i started the car, let my foot off the brake, then pressed the brake and just as i set my foot on the pedal it happened. radio went off and came back on. nothing else seems to be affected tho. not the lights, a/c, windows, guages, or engine.
any suggestion on what i should test? or replace first.
Thanks, Erich
post Oct 11, 2009 - 2:50 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Check the wiring, theres a short with either your radio wiring or your tail lights circuit.
Mike W
269awhp / 273ft-lbs
post Oct 11, 2009 - 6:22 PM
stl95celica
Joined Oct 22, '08
From St.Louis
check your battery conections...
-frank
post Oct 12, 2009 - 11:08 AM
richee3
Joined Jun 29, '08
From Denver
^^^ x2. I've seen it happen where the circuit can be broken for just a moment, just enough to shut the radio off, but it didn't seem to affect anything else because it wasn't off long enough. If everything is tight there, then I don't know what to tell you.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 12, 2009 - 11:11 AM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
I bet it does the same thing when you turn your wipers on right? my 89 was doing the same thing and I fixed it by giving my battery a good overnight trickle charge....I'm suspecting the alternator is on its way out though
ST205 Crew represent
Challenge Accepted
post Oct 12, 2009 - 11:37 PM
Badkarma
Joined Apr 23, '06
From Rochester, NY
wasn't raining, so didn't really try with the wipers. got it fixed for now tho. seemed to be the cable connections at the battery posts. the positive side was really corroded. i replaced the terminal 2 weeks ago, but it seems to be corroding quite fast. all problems are gone now. we'll see how long this lasts.
Erich
post Oct 13, 2009 - 12:49 AM
azian_advanced
Joined Apr 18, '05
From Calgary
it helps to lightly sand the battery terminals clean and add dielectric grease all around for improved connection and to reduce its chances for oxidizing..
how old is your battery btw?
Lo-Fi Version Time is now: January 14th, 2025 - 5:30 PM
