Enthusiast ![]() ![]() Joined Nov 23, '07 From NJ Currently Offline Reputation: 7 (100%) ![]() |
![]() ![]() Megan Racing Street Series Coilovers for 94-99 Toyota Celica FWD $850/set with Discount Code! Free Shipping (lower 48 states)! Brand New with Warranty! Simply enter code "6GCMRCDK" during checkout - follow the links below! Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications. The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you're a professional mechanic or an automotive enthusiast with amateur mechanical skills. The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car's handling capabilities. On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street. The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, Megan Racing stands by their product with a strong warranty. Features: Spring Rates: Front 10kg/Rear 8kg 32 Levels of Adjustable Damper Pillow Ball Upper Mounts Rubber Dust Covers Adjustable Ride Height Aggressive Spring Rates Single-Cylinder Design Aluminum Brackets 32 Levels of Adjustment: 1-8: Suggested for track use 9-16: Suggested for mountain/aggressive use 17-32: Suggested for common street use All coilover damper kits come with 1 year manufacture-defect warranty $850/set with Discount Code! Free Shipping (lower 48 states)! Brand New with Warranty! Simply enter code "6GCMRCDK" during checkout - follow the links below! Megan Racing Street Series Coilovers for 94-99 Toyota Celica GT/ST FWD ![]() ![]() ![]() ![]() This group buy is now open and active to all members. We can accept payment directly via Paypal or through our website checkout. For website checkout, enter code "6GCMRCDK" to receive discount! Megan Racing Street Series Coilovers for 94-99 Toyota Celica GT/ST FWD Megan Racing Street Series Coilovers for 00+ Toyota Celica Megan Racing Street Series Coilovers for 89-93 Toyota Celica All-Trac Megan Racing Street Series Coilovers for 90-93 Toyota Celica GT/GTS FWD Megan Racing Street Series Coilovers for 93-98 Toyota Supra Megan Racing Street Series Coilovers for 00+ Toyota MR2 Spyder Megan Racing Street Series Coilovers for 91-95 Toyota MR2 $850/set with Discount Code! Free Shipping (lower 48 states)! Brand New with Warranty! Simply enter code "6GCMRCDK" during checkout - follow the links above! Note to admins: Coomer has not responded to PM's. If there is another admin who needs to verify/approve this posting, please PM and let us know. ![]() ![]() ![]() ![]() ![]() This post has been edited by upscaleauto: Aug 27, 2010 - 7:53 PM --------------------
Lo-Fi Version | Time is now: April 23rd, 2025 - 1:27 AM |
