Feeler Project: Light Weight Pulley for 6GC, 3S for sure, and will make for 5S, 7A & 4A if feasible |
Oct 13, 2009 - 12:37 PM |
Enthusiast Joined May 25, '06 From Hong Kong Currently Offline Reputation: 256 (100%) |
Something like this:
I will def. make some for 3S, then I can test on before I proceed for other engines One thing, I have the following stocked pulley - 3SGE, 7AFE, 4AGE Don't have 5SFE, dunno 5S could share the same pulley with 3S? anyone know? This post has been edited by vincent_doggy: Oct 13, 2009 - 12:47 PM -------------------- |
Oct 13, 2009 - 9:24 PM |
Enthusiast Joined Jan 2, '07 From Little Rock, AR Currently Offline Reputation: 0 (0%) |
A quick check showed me that the crank pulley on my ST215 3SGTE was slightly smaller than the 5SFE crank pulley I had sitting in the garage.
ST215 3SGTE 136mm Alternator & AC belt Outside Diameter 100mm Power Steering belt Outside Diameter ST184 5SFE 145mm Alt & AC belt OD 100mm PS belt OD ST202 5SFE 145mm Alt & AC belt OD 100mm PS belt OD I don't have the 3SGTE crank pulley off right now so I can't measure the inside diameter (Crank hole). I'll probably get to it later this week as I'm working on my 3SGTE to get it ready to put it in my convertible. |
Oct 13, 2009 - 11:36 PM |
Enthusiast Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
uh 5s-fe in the st202? I think not
St202 3s-fe, 3s-ge. jdm St204, 5s-fe usd at200 7a-fe usd This post has been edited by Mstoochn: Oct 13, 2009 - 11:38 PM |
Oct 13, 2009 - 11:39 PM |
Enthusiast Joined Oct 20, '08 From Lima,Peru Currently Offline Reputation: 0 (0%) |
3sgte and 3sge are the same pulley
Oct 13, 2009 - 11:50 PM |
Enthusiast Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
Oct 14, 2009 - 12:07 AM |
uh 5s-fe in the st202? I think not St202 3s-fe, 3s-ge. jdm St204, 5s-fe usd at200 7a-fe usd LOL i was thinking the same thing just a quick question but aren't the pulleys for these cars balanced for their particular engine? yes, but the lighter they are the less moving mass easier to get those rpm's up! |
Oct 14, 2009 - 12:48 AM |
Enthusiast Joined Aug 5, '09 From Oakley, CA Currently Offline Reputation: 15 (100%) |
I want it.
-------------------- 1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver |
Oct 14, 2009 - 12:57 PM |
Enthusiast Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
If its done in a quick-ish time line (before i install timing belt here soon) you could probably count me in.
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Oct 14, 2009 - 6:28 PM |
Enthusiast Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
Just to give people a heads up, if you look at your harmonic balancer (as they are otherwise called) they have a layer of rubber between the innerm metal part that bolts to your crank and the outer ring that the belts run on. This is there to get rid of the "harmonic resonance" in the cranks and POSSIBLY make them run smoother and less chance of things going pear shaped, especially at high rpm. Toyota put things there for a reason in my opinion.
Im not trying to diswade you from buying this dudes product, i just thought you should know the facts before you commit to anything. There is no doubt lighter rotating mass is good though. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s |
Oct 14, 2009 - 11:02 PM |
A quick check showed me that the crank pulley on my ST215 3SGTE was slightly smaller than the 5SFE crank pulley I had sitting in the garage. ST215 3SGTE 136mm Alternator & AC belt Outside Diameter 100mm Power Steering belt Outside Diameter ST184 5SFE 145mm Alt & AC belt OD 100mm PS belt OD ST202 5SFE 145mm Alt & AC belt OD 100mm PS belt OD I don't have the 3SGTE crank pulley off right now so I can't measure the inside diameter (Crank hole). I'll probably get to it later this week as I'm working on my 3SGTE to get it ready to put it in my convertible. My bad. Yes the 5SFE is from a ST204. I've been searching Ebay for ST205 & ST202 parts for months. I got it stuck in my head somehow. Speaking of EBAY, I know I've seen a lightened 3SGTE pulley on their before. Iirc there was some issue of weather the 3SGTE was from a Celica or MR2 due to the belt setups. I don't know for sure, but I wanted to throw that out there in case it really is a problem. |
Oct 14, 2009 - 11:15 PM |
Just to give people a heads up, if you look at your harmonic balancer (as they are otherwise called) they have a layer of rubber between the inner metal part that bolts to your crank and the outer ring that the belts run on. This is there to get rid of the "harmonic resonance" in the cranks and POSSIBLY make them run smoother and less chance of things going pear shaped, especially at high rpm. Toyota put things there for a reason in my opinion. I'm not trying to dissuade you from buying this dudes product, i just thought you should know the facts before you commit to anything. There is no doubt lighter rotating mass is good though. I was under the impression that the rubber piece in the harmonic balancer acted kind of like Dynamat as it helps absorb or dampen vibrations from the engine. Isn't that due more for reduced noise, vibration & harshness (NVH), rather than to prevent things from going pear or egg shaped. It's definitely their for a reason, no doubt. Who here runs a lightened pulley? Does it vibrate more at a certain RPM than before? |
Oct 14, 2009 - 11:16 PM |
No harmonic balancer = will not buy.
Oct 14, 2009 - 11:38 PM |
last time i checked, i don't remember seeing anything rubber on the 5sfe crank pulley.
vince, you probably should state what sort of metal will be used or if there's any sort of additional manufacturing treatment the pulleys will undergo to resist warp against engine bay heat and high rpms. the last thing you'd want is for these to go bad on people. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Oct 15, 2009 - 6:14 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
sounds pretty good to me. Question is which one pulley it should be? Or it should be any of below?
If there is clear answer what part we talking about I can find in EPC if part numbers are the same for all Celica engines... -------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
Oct 15, 2009 - 7:15 AM |
the CK
Oct 15, 2009 - 6:05 PM |
on the mr2 the alternators is down basically where the power steering pump is on the 3s-g
so the grooved sections where the belts run are the same diameter, insted of the inner one being smaller like the 3s. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
Oct 16, 2009 - 3:04 AM |
I have some answers folks about that crank pulley compatibility (according to OEM part numbers) seems we have 5 different ones:
US 7AFE 13470-16090 EURO 7AFE (I can send it to Vincent since I have one on my old 7AFTE but I do not think there will be anyone from Europe with 7AFE who wants it) 13470-16050 5SFE and 3SFE 13408-74041 3rd gen 3SGE (non Beams) 13407-88380 3SGTE and 4th gen 3SGE (Beams) 13407-88480 what is real difference (material, size... anything) I do not know... This post has been edited by malpaso: Oct 16, 2009 - 3:07 AM -------------------- No more replicas... This is evolution... This is SS-four :)
Oct 20, 2009 - 7:07 AM |
found this on ebay from Poland
QUOTE Alloy Crankshaft Pulley Alloy Crankshaft Pulley, CNC machined, Light weight to reduce power loss. Timing mark machined. High quality product. For any questions please feel free to contact me at: suspension@gt4.com.pl ALLOY CRANKSHAFT PULLEY CELICA ST202, ST204 -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Oct 20, 2009 - 12:12 PM |
Enthusiast Joined Dec 15, '08 Currently Offline Reputation: 0 (0%) |
found this on ebay from Poland QUOTE Alloy Crankshaft Pulley Alloy Crankshaft Pulley, CNC machined, Light weight to reduce power loss. Timing mark machined. High quality product. For any questions please feel free to contact me at: suspension@gt4.com.pl ALLOY CRANKSHAFT PULLEY CELICA ST202, ST204 I run this pulley in my 3sgte engine for 2 years now, it's still like new |
Mar 22, 2010 - 7:15 PM |
Enthusiast Joined Jan 15, '10 From germany Currently Offline Reputation: 0 (0%) |
have to dig this out.
did you proceed with the project? iam searching a ST215 alt - aloy pulley. |
Lo-Fi Version | Time is now: November 23rd, 2024 - 1:30 PM |
