> GT4 hood scoop idea
post Oct 18, 2009 - 6:05 PM
black13
Joined Oct 11, '06
From calgary
Looking at the GT4 hood with there just being a whole in the middle of the hood, wouldn't it be better if it had the WRX style hood scoop as air would better get sucked in and also water wouldn't drip in there if you remove the rain gaurd.
Like this.....
This post has been edited by black13: Oct 18, 2009 - 6:05 PM
post Oct 19, 2009 - 5:29 AM
QUOTE (black13 @ Oct 18, 2009 - 6:05 PM) *
Like this.....
no.
post Oct 19, 2009 - 9:37 AM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
IT'S NOT A SCOOP!!!!
It's a vent.....lolz
ST205 Crew represent
Challenge Accepted
post Oct 19, 2009 - 11:41 AM
yellowchinaman
Joined Aug 11, '08
From London
The purpose of the vent on the GT4 is to let heat out from the Turbo and manifold. Not to low air in. It's a different concept with the Scoobies.
post Oct 19, 2009 - 1:23 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
^+1
The Scoobies have the scoop there to aid in guiding air INTO the air to air intercooler that sits on top of the motor. Much like the st185. If you do a google search, you will notice the change from a scoop to a vent in the st185 to the st185RC/CS and the st205. The water to air intercooler does not require the air flow as it uses its own working fluid to transfer heat. Thus, no need for a scoop.
The vent was added in its place to aid in reducing the under-hood temps resulting from the turbo/exhaust assembly.
~bloodMoney
post Oct 20, 2009 - 12:37 AM
black13
Joined Oct 11, '06
From calgary
thanks for the info. Was just an idea.
Lo-Fi Version Time is now: November 27th, 2024 - 4:43 PM
