3SGE GEARBOX MOUNT |
Oct 19, 2009 - 3:44 PM |
Enthusiast Joined Apr 28, '07 From Venezuela Currently Offline Reputation: 0 (0%) |
Hi!... Anyone knows wich rear mount i have to use to put a 3SGE gearbox into a 97 GT?... The other three mounts works just pefectly but the rear mount dosnt
Oct 19, 2009 - 4:17 PM |
The 3sge tranny is the s54 , same as the gt.
mounts are the same. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Oct 19, 2009 - 4:59 PM |
The 3sge tranny is the s54 , same as the gt. mounts are the same. you have to align the tranny first. you might have to fit the rear first and then the rest. Also what other three fit are you talking about there are only 3 on the tranny side. The other is the engine mount that you don't need to worry about. This post has been edited by trdproven: Oct 19, 2009 - 5:00 PM -------------------- 94 Celica GT
Oct 19, 2009 - 8:50 PM |
Enthusiast Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
Oct 19, 2009 - 11:25 PM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
far as I know only the 94 SS-II 3S-GE with superstrut came with the E56, or otherwise it was a rare option in SS-II/III
Oct 20, 2009 - 4:07 PM |
far as I know only the 94 SS-II 3S-GE with superstrut came with the E56, or otherwise it was a rare option in SS-II/III its the same as the s54. same exact thing, add LSD. mounts are exactly the same. -------------------- Former Team 5SFTE pro member ;)
Oct 20, 2009 - 11:40 PM |
yup, but also has a gearbox external oil cooler
Oct 26, 2009 - 3:25 PM |
Hi 6GC friends!... Ill try to put the rear mount this weekend without any good results!.... The rear mount donīt fit ... The mount its too far from the bracket
Here ill post some pic! (the left bracket its the bracket from de rear 3SGE box and the other one its the brackets from my stock gearbox from a 3SFE). Wath i can do? any ideas? |
Oct 27, 2009 - 12:28 AM |
http://www.toyodiy.com/parts/p_J_1996_TOYO...BLMVF_1107.html
http://www.toyodiy.com/parts/p_J_1996_TOYO...MVF_1107.3.html -------------------- |
Oct 29, 2009 - 5:46 PM |
Oct 30, 2009 - 3:04 PM |
Nov 2, 2009 - 12:52 AM |
hmm there are 3 to use, if you click my above link you'll see your 2 brackets in the picture, are the same as your picture. tried using your old bracket does that fit?
12321-74320 12321-74321 12321-74340 -------------------- |
Nov 7, 2009 - 7:48 AM |
no, my old bracket dosnt fit!.. i already get the solution to the problem improving a custom rear mount
Nov 9, 2009 - 7:45 PM |
i found that my gearbox its an E58!.. Now i have some problems with the axles! any idea on what axles will fit up?
Lo-Fi Version | Time is now: December 2nd, 2024 - 12:21 AM |
