> Will this fit?
post Jan 14, 2003 - 3:18 PM
NiTTo
Joined Dec 25, '02
From The Netherlands
http://www.toyota.nl/g/g01_09_20.html
This engine (2.4 VVT-i) is from an http://www.toyota.nl/g/g01_09.html Toyota Previa.
115 kW (156 pk)/5600
225 Nm/4000
154 Hp/5600
166lbft/4000
Only problem: will it fit? biggrin.gif
post Jan 15, 2003 - 11:43 AM
NiTTo
Joined Dec 25, '02
post Jan 15, 2003 - 10:54 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
probably not... would need to see the engine code to tell you for sure but really dont think that it would fit
post Jan 16, 2003 - 12:30 PM
NiTTo
Joined Dec 25, '02
mad.gif damn.....
post Jan 16, 2003 - 1:54 PM
1_Winged_Angel
From Bay Village, OH
Yes... It will fit. Actually I should put it this way. Anything will fit with enough knowledge and money
post Jan 16, 2003 - 5:14 PM
0Re0
Joined Nov 13, '02
From Hawaii
QUOTE (1_Winged_Angel @ Jan 16 2003, 11:54 AM)
Werd
post Jan 17, 2003 - 3:44 AM
BillyBob
Joined Jan 15, '03
From Waipahu, Hawaii
i wanna see a v12 in a metro. or has it already been done? i'm guessing it can with major body work and adjustments.
post Jan 17, 2003 - 1:32 PM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
might as well do a 20v swap.... it might be easier and probably cheaper
post Jan 17, 2003 - 7:12 PM
boosted_K2
Joined Aug 30, '02
From Michigan
it wouldnt be a direct swap by any means into a GT or ST... and with those #s having VVT-i wouldnt really be worth it anyways... it would more than likely perform to 7th gen GT standards, probably beat it but it would be close. if you want VVT-i that bad go for the 3sge VVT-i verson, youll be alot better off...
No but I don't buy it
Cause I'm...
post Jan 18, 2003 - 2:40 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
post Jan 20, 2003 - 3:24 PM
95STCelica
Joined Oct 12, '02
From New Jersey
so are you saying that i could get a jet engine in my 7afe with enough money lol..oh and knowledge biggrin.gif
post Jan 20, 2003 - 6:50 PM
west_minist
Joined Oct 27, '02
From Barbados
QUOTE (NiTTo @ Jan 14 2003, 04:18 PM)
225 Nm/4000
154 Hp/5600
166lbft/4000
If you are planning on pulling boat, go ahead.
Most probably, this is a F head and not the G head. The torque actually says that.
Please do not waste time with this engine.
Go for a 3SGE or 3SGTE engine and do some light mods for alot of hp.
You will be well over the 220 for HP and torque to begin with.
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Jan 21, 2003 - 12:54 AM
sirrahtap
Joined Dec 1, '02
From minneapolis
QUOTE (95STCelica @ Jan 20 2003, 01:24 PM)
actually i saw a site a while back that had an old mr2 that was jet powered. it had the engine completely taken out. in the front, they put a little honda weedwacker or lawnmower engine to use as a fuel pump, then it had 3 jet turbines in the back.
http://www2.msstate.edu/~sgn1/MR2/mod/turbine.htm
check it....this thing is nuts
post Jan 21, 2003 - 4:42 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
umm I really wouldn't waste my time with that either- if you want a unique swap try a 3.0 camry engine- I bet you could do that for about the same amount o' money- or am I nutz
Lo-Fi Version Time is now: November 25th, 2024 - 7:18 AM
