2 Pages V  < 1 2
> front mount or A2W??, i want your opinon
post Dec 20, 2009 - 7:01 PM
6gtfour
Joined Sep 14, '09
I have this bad habit of oversimplification of everything. That said. this whole discussion means nothing to me. I'm concerned about two things. 1 after cooler air intake temperature, and 2, the presence of engine knock or lack thereof.
Until someone can show me log files of the aftercooler temperature from an air to air setup and a water to air setup as well as logged counts of knock with both setups under similar ambient temp/load environments, I'm just not going to decide which one is better.
post Dec 20, 2009 - 7:27 PM
QUOTE (6gtfour @ Dec 20, 2009 - 7:01 PM) *
Both setups work. You might get some statistics that show things one way or another, but the truth is that both setups work and have been used in millions of cars all over the world. Its just a matter of flipping a coin and deciding what setup you personally like more.
post Dec 20, 2009 - 7:36 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
QUOTE (lagos @ Dec 20, 2009 - 8:27 PM) *
Well said.
330whp 309ft/lbs @ 21 PSI
post Dec 21, 2009 - 12:06 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
be aware if u chose to use the stock wrc top mount a2w intercooler and your powergoals are WAYYY up there the heat exchanger and pump will need to be upgraded in order to match that of a FMIC a2a. in the range of 400+whp unless im mistaken.
post Apr 15, 2011 - 7:58 PM
Detatch
Joined Sep 28, '09
From Washington, MO
anyone know how to get the oem st204 hood to close with an st205 w2a intercooler? runing the wrc engine and wanting to keep the w2a i/c...
post Apr 16, 2011 - 12:54 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Yes. No fitment issue. As per your other thread.
Mike W
269awhp / 273ft-lbs
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 23rd, 2025 - 3:44 AM
