> tom's lip help, install
post Oct 27, 2009 - 9:05 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
Hey i recently just bought and fixed a tom's lip and I was wondering how would I be able to bolt up where the lip sits inside the wheel well to my fender its missing a hole. Also does anyone how i would be able to bolt up a part of it that is missing one of the mounting brackets? there's little mounting brackets on the lip but one of them I guess ripped off, where can i find a replacement and a better question do i need this?
post Oct 27, 2009 - 9:32 PM
Shigexile
Joined Oct 30, '03
From IL
what i did for my splitters is drilled a new hole and also used double sided automotive tape for the mounting parts that ripped off mine.
post Oct 27, 2009 - 9:33 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
I was considering that but wasn't sure how well it would hold
post Oct 27, 2009 - 9:42 PM
post a pic of the missing bracket
post Oct 27, 2009 - 10:43 PM
stetsonaw
Joined Aug 3, '07
From Bellevue, Nebraska
when i had my toms lip on my celi (before i left japan), all i had mounting it was doublesided tape, never had any problems. no screws or anything.
~Andy
Check out my Droid Goodies
| My Flickr
post Oct 27, 2009 - 11:00 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
QUOTE (stetsonaw @ Oct 27, 2009 - 11:43 PM) *
well i want this thing to not rip off while im going through the car wash i work at
post Oct 27, 2009 - 11:36 PM
do you just have the bracket missing or its broken, you know you can make one.
post Oct 27, 2009 - 11:47 PM
stetsonaw
Joined Aug 3, '07
what car wash is that? i work in bellevue.
~Andy
| My Flickr
post Oct 28, 2009 - 12:01 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
QUOTE (njccmd2002 @ Oct 28, 2009 - 12:36 AM) *
I'm missing the far passenger side c clamp, not really sure how to make one, i have no welding skills
QUOTE (stetsonaw @ Oct 28, 2009 - 12:47 AM) *
russell speeders on 156th and maple, stop up sometime on the weekends that's when I work.
post Oct 28, 2009 - 12:13 AM
stetsonaw
Joined Aug 3, '07
QUOTE (freddy121389 @ Oct 28, 2009 - 12:01 AM) *
i'll swing by saturday and see what you're talking about. what time you work til? gotta head up to fremont, i'll swing by there on the way.
~Andy
| My Flickr
post Oct 28, 2009 - 4:24 AM
trdproven
Joined Aug 2, '05
From Guam
you just need enough brackets to hold in place some in the middle and some towards the fender. if thats oem, all you need is double sided tape, if the tape can't hold it close to the body all you do is tap screw it meaning on the part that hugs the fender the rest is just doublesided
This post has been edited by trdproven: Oct 28, 2009 - 4:24 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 28, 2009 - 9:45 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
QUOTE (stetsonaw @ Oct 28, 2009 - 1:13 AM) *
i work 2-9, i wont have the lip on the car, its sitting in my garage til i get it painted. I'll post pictures in a little bit of what I'm talking about, I do need c clamps but i also need one of the metal brackets that are on the inside of the lip that help it bolt to the bumper.
post Oct 28, 2009 - 9:50 AM
you can make those brackets from fiberglass too,
post Oct 28, 2009 - 10:20 AM
whatthe
Joined Aug 13, '08
From Australia
I can take pics of my toms lip brackets when its day for you.
post Oct 28, 2009 - 10:46 AM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (freddy121389 @ Oct 29, 2009 - 12:45 AM) *
it doesn't have to be that secured not all brackets need to be used. Just enough, remember not only does it hang on the inside of the bumper but it also has doublesided tape to hold it up too. Not only that you have bolts on the bottom.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 28, 2009 - 11:53 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
see this is the spot im missing one, its the one on the farthest side, Do you guys think it would matter all that much if i just skip it?
post Oct 28, 2009 - 1:59 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
I made new brackets by going to home depot and buying the 6inch long by 1inch wide aluminum plates. They are pretty thin and easily bent to shape. They were like 89c each and I drilled holes in them for mounting both to the body and the splitters.
post Oct 28, 2009 - 5:18 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
QUOTE (Harold_Fastwaker @ Oct 28, 2009 - 1:59 PM) *
good suggestion, i'll go to home depot here in a little bit and see if i can find one
post Oct 28, 2009 - 7:10 PM
those things that hold it are called rivets, the riveter is like 20 bucks at the depot and each rivet is like 10 cents
post Oct 28, 2009 - 8:14 PM
azian_advanced
Joined Apr 18, '05
From Calgary
you don't need to worry about that missing bracket. the middle section of the lip will wrap itself to the lower lip part of the front bumper. you just need to screw it to the fender wheel wells (right in front of the front wheels) and it'll hold fine. no double tape needed really thanks to the accurate fitment.. as long as you screw them against the fender wheel well at the right height. i'm not using ANY of the bottom brackets on mine. just two screws with one on each side.
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 13th, 2025 - 3:49 AM
