> 3Sgte into 7a-fe, HELP
post Jan 14, 2003 - 3:19 PM
L-Sport
Joined Jan 14, '03
From Montreal
I'm in the process of doing this swap, and have run into trouble with the engine mounts. Now i realize that this swap is only bolt in for the 2.2 powered Celicas. What can i do to regulate this problem? Use 2.2 mounts? Custom mounts?
thanks
post Jan 14, 2003 - 3:48 PM
forkee
Joined Nov 13, '02
From So Cal
yup mounting will be a problem, talk to some people from celica.net. there are a few who have done it from ST's. it is a lot more work than the 4age, which allegedly falls right in.
post Jan 14, 2003 - 6:16 PM
L-Sport
Joined Jan 14, '03
From Montreal
post Jan 14, 2003 - 6:40 PM
Guest_Jason_*
I could be wrong, but I thought the 3S-GTE mounted to our ST's alot easier than to GT's.
post Jan 14, 2003 - 8:47 PM
Cragspider
Joined Aug 30, '02
From Franklin,Tn
QUOTE (Jason @ Jan 14 2003, 05:40 PM)
No its a whole lot easier for the gt guys to just drop in the 3s. The reasons why this is that there ac unit and some other stuff fit. If we st guys were gona do it we have to get either the gt tranny and axles or we could use the MR2 turbo tranny and get custom axles made. Also we have to get some parts from a gt if we want a/c and what not. If you want a good idea of how much your gona spend on the 3s swap if you have a st check out Top Shelf Racing its got the comeplete list of what you would need and prices.
Bryan
post Jan 14, 2003 - 11:55 PM
Also, the 5S-FE and the 3S-GTE can use the same engine mounts, because they're both s-series engines. The 7A-FE is an a-series engine, so it'd require new motor mounts to drop in a 3S-GTE.
post Jan 15, 2003 - 9:28 AM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
i think you can use gt mount not sure tho there's a 3sgte sticky on the 6th gen forum in celica.net .... that might help
post Jan 19, 2003 - 3:37 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
[QUOTE]Cragspider Posted on Jan 14 2003, 06:47 PM
he's right, - I would recommend 4agze
Lo-Fi Version Time is now: December 1st, 2024 - 1:56 AM
