Antifreeze, where to buy it? |
Oct 29, 2009 - 3:30 AM |
Where does everyone get there toyota red antifreeze at?
My local dealer wants 22 bucks a gallon for it. Its not expensive considering you only change it every 100k miles. But I have to maintain 6+ toyota in the family and that is gonna hurt. So does anyone know where to get some cheap toyota red antifreeze? |
Oct 29, 2009 - 11:23 PM |
Cheap. Toyota. Pick one.
That said, try an online dealer such as 1sttoyotaparts.com, they operate out of a dealership so the parts are OEM but the prices involve less overhead. |
Oct 30, 2009 - 12:06 AM |
i heard car quest has red antifreeze but i'm not sure if it is any good.
I'm not asking for bargain prices on antifreeze, Just cheaper then 22 dollars a gallon. I will be needing around 6 galls taht is over $100 for antifreeze. |
Oct 30, 2009 - 1:03 AM |
Enthusiast Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
i heard car quest has red antifreeze but i'm not sure if it is any good. I'm not asking for bargain prices on antifreeze, Just cheaper then 22 dollars a gallon. I will be needing around 6 galls taht is over $100 for antifreeze. i think i saw in car quest catalog that they sell toyota red coolant there. -------------------- God made man....
Everything else... Made in China |
Oct 30, 2009 - 1:11 AM |
Enthusiast Joined Aug 6, '09 From Bergen County,NJ Currently Offline Reputation: 10 (100%) |
Hmm so my coolant is trash? I bought Prestone thinking it didn't matter what you got. A bit late now but would this cause any issues?
-------------------- 1996 Toyota Celica ST 25th Anni. Edition #461
Oct 30, 2009 - 9:21 AM |
You're fine. Standard green coolant is all I ever use.
Oct 30, 2009 - 7:52 PM |
Hmm so my coolant is trash? I bought Prestone thinking it didn't matter what you got. A bit late now but would this cause any issues? coolant is coolant. All it does is: 1) keep different metals from reacting to water causing corrosion. 2) keep water from freezing 3) lubricate the water pump saying that, there are different schools of thought about the optimum antifreeze formula. Being a toyota fanboy I like to stick with what toyota engineers come up with. |
Oct 31, 2009 - 3:27 AM |
Got ya. So need to do worry, also might be a little off topic but I've been recommended something called Purple ice. I think thats what I was told don't quite remember, it had something to do with helping with the cooling of your engine. Anyone try this?
Oct 31, 2009 - 10:22 AM |
keep in mind though that you can buy straight from toyota and then mix it with distilled water 50/50. if you have toyota red then stick with toyota red or flush your system totally then change to green or something else cheaper. mixing coolant chemistrys can cause problems.
Nov 2, 2009 - 5:11 AM |
Enthusiast Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) |
Mixing coolant will eventually end like this:
Gone oem headgasket: -------------------- JDM ST205
Lo-Fi Version | Time is now: November 25th, 2024 - 12:49 PM |
