troubleshooting Power windows problem, passenger power window not working |
Oct 29, 2009 - 3:03 PM |
Enthusiast Joined Oct 7, '09 From indianapolis Currently Offline Reputation: 0 (0%) |
hi, how do i trouble shoot the power window ,
even though i don't think is related , i was working on the radio, and took off the previous radio and installed a new one. after that , the next morning the passenger side power windows doesn't roll down, although the driver's side does work. what can i do to find the problem and then fix it? any help and links would be appreciated!! |
Oct 29, 2009 - 3:08 PM |
Enthusiast Joined Apr 6, '08 From Overland Park Currently Offline Reputation: 9 (100%) |
hi, how do i trouble shoot the power window , even though i don't think is related , i was working on the radio, and took off the previous radio and installed a new one. after that , the next morning the passenger side power windows doesn't roll down, although the driver's side does work. what can i do to find the problem and then fix it? any help and links would be appreciated!! ...this has happened to me... check ur window lock... good chance you accidentally bumped it or something and locked it.. GL -------------------- |
Oct 29, 2009 - 3:31 PM |
hi, how do i trouble shoot the power window , even though i don't think is related , i was working on the radio, and took off the previous radio and installed a new one. after that , the next morning the passenger side power windows doesn't roll down, although the driver's side does work. what can i do to find the problem and then fix it? any help and links would be appreciated!! ...this has happened to me... check ur window lock... good chance you accidentally bumped it or something and locked it.. GL where is it at? my window still rolls down thou? |
Oct 29, 2009 - 6:53 PM |
Enthusiast Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) |
hi, how do i trouble shoot the power window , even though i don't think is related , i was working on the radio, and took off the previous radio and installed a new one. after that , the next morning the passenger side power windows doesn't roll down, although the driver's side does work. what can i do to find the problem and then fix it? any help and links would be appreciated!! ...this has happened to me... check ur window lock... good chance you accidentally bumped it or something and locked it.. GL where is it at? my window still rolls down thou? It's right next to the power window down/up button; just above the passenger side window up/down toggle. -------------------- Has no more Celicas
Oct 29, 2009 - 7:46 PM |
thanks!!! this thas had to be the easiest fix ever lol!!!
(but seriously, i feel stupid now) |
Oct 29, 2009 - 8:32 PM |
yeah... I did too.. ha ha its all good tho
Oct 29, 2009 - 10:45 PM |
and i think there has been two similar threads in the past... so you're not the only one. lol
Nov 24, 2009 - 1:22 AM |
Enthusiast Joined Jul 7, '08 From California Currently Offline Reputation: 0 (0%) |
hi, how do i trouble shoot the power window , even though i don't think is related , i was working on the radio, and took off the previous radio and installed a new one. after that , the next morning the passenger side power windows doesn't roll down, although the driver's side does work. what can i do to find the problem and then fix it? any help and links would be appreciated!! This is the same problem I'm dealing with right now. The issue with mine is that it is the rear passenger side window. I had a friend pull out my radio and I'm not sure if this is related, but my window doesn't work anymore. So... I tore it apart and now have the window power motor out. At this point everything that I've troubled shot leads me to believe that that my motor is no longer working. The cheapest but riskiest route for a replacement, is buying one a wrecking yard. So good luck with your trials. I'll keep you posted on my endeavors! |
Lo-Fi Version | Time is now: November 22nd, 2024 - 9:41 PM |
