Strange oxygen sensor\lambda sonda ..., 3SGE 6 gen |
Nov 1, 2009 - 10:01 AM |
Enthusiast Joined Jan 16, '09 From Cyprus Currently Offline Reputation: 10 (100%) |
Hello
so i was thinking to change my oxygen sensor but when i disconect it from my car i was surpised...its look like no other sensor that i've been seen before on the shops! Also it is strange that she stay after the catalyst? i thing maybe this is "exhaust gas temperature sensor" what do you thing? i have only this sensor under my car If someone have info please write it here thanks Cheers p.s. the car is JDM Celica GT st202 1994 year with 3SGE engine ! p.s. i know its easy to order from Toyota but it cost 200 euro..WTF This post has been edited by cyprus_gt: Nov 1, 2009 - 11:16 AM -------------------- |
Nov 1, 2009 - 11:11 AM |
Enthusiast Joined Nov 4, '06 From POLAND Currently Offline Reputation: 0 (0%) |
this is EGT ,
lambda should be in Y-pipe before catalyst -------------------- BEAMS swaped .......
Nov 1, 2009 - 11:46 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
I found three part numbers for it on toyodiy (which cover ST202 & ST205)
89465-20580 89465-20620 89465-29695 -------------------- |
Nov 1, 2009 - 1:17 PM |
this is EGT , lambda should be in Y-pipe before catalyst Thanks man i've just check and saw the lambda sensor on the Y-pipe so will see how many wires have and will order some universal becouse the original from Toyota is very expensive! btw. this EGT sensor is need to be changed on some km. or years? thanks CHEERS -------------------- |
Lo-Fi Version | Time is now: November 29th, 2024 - 4:34 AM |
