> Bearings maintenance
post Nov 3, 2009 - 9:08 PM
fran
Joined Apr 28, '07
From Venezuela
post Nov 3, 2009 - 9:26 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
you lubricate them by buying new wheel bearings.
post Nov 3, 2009 - 9:48 PM
Hanyo
Joined Aug 16, '03
From Bay area
you can repack them with grease. But if you notice any noise from them; chances are they are shot and you need new ones. I recommend you change them soon before they damage the spindale which required replacing the hub.
post Nov 3, 2009 - 10:15 PM
Bitter
Joined Mar 11, '06
QUOTE (Hanyo @ Nov 3, 2009 - 9:48 PM) *
no, you can't they're ball bearings in plastic cage. actually they're not even supposed to be seperated from the races prior to installation. you press the bearings into place and thats it. you can try to add some grease but if they've ran out of grease then they're done for. its not like a roller bearing where you need to pull them apart and grease them every XXX miles.
post Nov 3, 2009 - 11:18 PM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE (Bitter @ Nov 3, 2009 - 9:15 PM) *
This.
Just replace them, they're sealed units.
1999 Celica GT
post Nov 4, 2009 - 1:42 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (Bitter @ Nov 3, 2009 - 7:15 PM) *
woops i must have gotten them confused with another car. I forgot the celica had a sealed unit.
post Jan 11, 2010 - 10:03 AM
fran
Joined Apr 28, '07
From Venezuela
Anyone know the part number for those bearing? front; left and rigth. (97 ss-I)
post Jan 11, 2010 - 11:06 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
You can grease the bearings, use some high temp wheel bearing grease and spread it evenly across the metal balls.
post Jan 11, 2010 - 9:44 PM
Bitter
Joined Mar 11, '06
QUOTE (soulshadow @ Jan 11, 2010 - 11:06 AM) *
yes, but you'd have to press them apart to get at them laugh.gif and if you're going to press them apart you'll be replacing them. you can grease the new ones if they do not come greased.
post Jan 12, 2010 - 11:47 PM
Penkka
Joined Dec 20, '07
From Valkeakoski, Finland
anyone has a wheel bearing loose, IŽd need the measures of front bearing..
320hp @ 6300rpm and 420Nm @ 3250rpm. yay!
My ST205 WRC buildthread
Lo-Fi Version Time is now: January 11th, 2025 - 7:53 PM
