> surging rpm
post Nov 7, 2009 - 12:29 AM
Joe_1985
Joined May 3, '09
From jacksonville/flemming island florida
well i just noticed this tonight, after i drove my 25 mile drive home and parked in my driveway, I noticed that my rpm would float between 1000 and 700 very slowly.
so i got out and stood behind my car and listed to the exaust (its stock) and id hear the rpms slowly go down to about 700ish rpm , sputtering missfire, then jump back up to 1000ish, sit for a second or 2 then slowly fall sputtering missfire, then repeat.
when i got the car i changed the cap, plugs, wires, rotor button, cleaned out the intake manifold, and throttle body.
ill check the plugs in the morning.
it also surges up and down the rpm range if i hold the gas steady, does the same thing falls very slowly then goes back up.
btw this is a 7afe with 189,000 miles on it
94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine
85 celica gt-s project
post Nov 7, 2009 - 1:28 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (Joe_1985 @ Nov 7, 2009 - 12:29 AM) *
vac leak in the brake booster, shine a light into the plug wells, see if any of the spark plugs are wet. (oil leak)
post Nov 7, 2009 - 2:45 AM
Joe_1985
Joined May 3, '09
plugs are dry
did the tube seals
pulled all 4 plugs, they gave me the impression the engine is running lean.
cleaned em and reset the ecu, surge gone
drove around for a bit, still lean
timing is 2 degrees advanced
i think something may be amiss
only parts left to check or replace are..
fuel pressure regulator
injectors
o2 sensors
egr, i had this mess up on one of my celicas, made it run lean
may go to the junkyard later on and grab all said parts and see if there is any differnce, untill then anyone got any ideas
about the brake booster vac leak, ive had that happens it makes a odd but distinct sound so thats not it
post Nov 7, 2009 - 3:06 AM
trdproven
Joined Aug 2, '05
From Guam
check your distributor position too.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Nov 7, 2009 - 10:39 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
reset your ecu air/fuel mix, there is a good write up on the how to section, hope this helps
2001 Solar yellow Lexus IS300
post Nov 7, 2009 - 5:05 PM
Mstoochn
Joined Apr 27, '09
why is your timing advanced.... 7a-fe shouldn't be adjusted
post Nov 7, 2009 - 5:47 PM
Joe_1985
Joined May 3, '09
QUOTE (Mstoochn @ Nov 7, 2009 - 6:05 PM) *
why did you post a reply, your reply was neither helpful or useful
to everyone else, thank you
post Nov 7, 2009 - 5:53 PM
Mstoochn
Joined Apr 27, '09
QUOTE (Joe_1985 @ Nov 7, 2009 - 6:47 PM) *
A/F is going to be off if your firing is advanced beyond Zero degrees, without the proper A/F ratio to begin with of course your going to be running lean, also causing lean missfires when there is too little fuel in the mix that relate to what is known as floating rpm. if the ecu is similar to the 5s, the ecu controls timing (aside from cam gears, or the cams being set wrong to begin with)
look at your fuel system as well. Filter is most probable
if your EGR was a miss your car would smell HORRIBLE, almost intoxicating.
Fuel economy bad?
This post has been edited by Mstoochn: Nov 7, 2009 - 6:05 PM
post Nov 8, 2009 - 1:46 AM
Joe_1985
Joined May 3, '09
ive changed the fuel filter
the last 2 things ill check is the mechanical timing (cam gear in relation to the crank at tdc) and the fuel pump sock filter\
my fuel economy isnt bad imo im getting 32mpg mixed driving
ill try the a/f reset as well as put the timing back to stock
Lo-Fi Version Time is now: December 3rd, 2024 - 2:36 AM
