> how to clean alternator
post Nov 7, 2009 - 10:43 PM
Hanyo
Joined Aug 16, '03
From Bay area
when ever i detail my engine bay i always avoid putting a water in it.
So how do you suppose to keep the alternator clean? Or more importantly how do you clean it?
post Nov 9, 2009 - 7:01 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Depends on the finish -- if it's your typical aluminum case, metal polish. If you really want it to shine, pull it, remove the case and polish a finish onto it (steel wire wheel works well for a machined finish). I cleaned mine with a rag and light degreaser, then used silver polish on it.
post Nov 9, 2009 - 7:45 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
if you want it to look professional you need to split the case and get it vibro-polished then buffed. theres just no way to hit all the little corners otherwise.
post Nov 9, 2009 - 8:04 PM
Hanyo
Joined Aug 16, '03
From Bay area
not really into want to get it polished clean. I just want to clean it so it looks clean like the rest of my engine bay. At the moment it is the dustiest part under the hood.
post Nov 9, 2009 - 8:13 PM
Bitter
Joined Mar 11, '06
in that case, just take a brass or stainless steel brush to it. its not dust, its corrosion. clean the surface and paint it silver.
post Nov 10, 2009 - 12:37 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (Bitter @ Nov 9, 2009 - 5:13 PM) *
it dust. If i took a pressure water to my alternator it would brand new.
But from my past experience water in the alternator is not good. The last time I pressure washed the engine a check engine light came on and i have to physically go through ALL the connectors with an air compressor. That was not fun.
Lo-Fi Version Time is now: December 2nd, 2024 - 5:48 AM
