trying to finalize a leak |
Nov 10, 2009 - 2:52 AM |
Enthusiast Joined Jul 23, '08 From Hawaii Currently Offline Reputation: 6 (100%) |
finally got around to work on the 5sfe..
dropped the panels and found a couple of the tranny side pan flange bolts loose, so I tightened those down and checked the engine side. after a bit of checking tightness and poking around, started up the car and noticed a steady stream coming down in or next to the timing belt cover... I haven't checked in a manual yet on how that area is all setup, but i'm guessing i'll have to order a lower engine gasket set and just change everything out that I can get to without pulling the engine. It could be the crank pulley seal or maybe the oil pump seal?? everything is covered in oil underneath heh... |
Nov 10, 2009 - 4:06 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
oil pump seal
cam seals?? LMK if you need help. shoot me a pm here or on FH cuz phone is goners -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Lo-Fi Version | Time is now: December 4th, 2024 - 11:18 AM |
