2 Pages V  < 1 2
> Plugs and Wire change gone bad, 10 min. job turns into a 2 day plus job
post Nov 12, 2009 - 12:15 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
Where in PA are you?
post Nov 12, 2009 - 12:42 PM
Bigblock
Joined Feb 14, '09
From Mid West
Can you get one of those cheap box cutters--long narrow plastic that has a razor in it,then extend the blade long enough to reach the rubber,then slice the rubber in a few places,then use a shop vac or vacuum cleaner with an attachment to clean out the pieces?
Maybe this would also free the pliers??
post Nov 12, 2009 - 2:03 PM
babi_boi
Joined Feb 10, '09
From pa
QUOTE (AMCMoe @ Nov 12, 2009 - 1:15 PM) *
Wellsboro PA, Maybe 20-25 mins away from Mansfield University.
QUOTE (Bigblock @ Nov 12, 2009 - 1:42 PM) *
I can attempt to do it. I have a whole box of those box cutters, so i will see what i can come up with.
BABI BOI
post Nov 12, 2009 - 2:52 PM
bmj67
Joined Oct 23, '08
i would not drill the pliers because when you do get them out there will be shaving in the plug tube and once you pull the spark plug they will fall into the cylinder. try to spray wd40 down in the tub then use the needle nose vise grips on the pliers and push down and twist side to side
post Nov 12, 2009 - 3:56 PM
babi_boi
Joined Feb 10, '09
From pa
Ok so i finally got the pliers out, and all the peices of rubber. All that is left is to put it all back together. Thank you everybody for all the ideas and advise. Galcobar's idea about removing the tube was what got everything back to the way it was suppost to be. Again thank you everybody.
BABI BOI
post Nov 12, 2009 - 5:44 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Wow, what a process. Well im glad that you got them out, now you can wrap it up and be done with it.
post Nov 12, 2009 - 5:50 PM
bmj67
Joined Oct 23, '08
dont forget to use sealant on the bottom of the tube when you reinstall it or it will leak oil
post Nov 12, 2009 - 6:29 PM
babi_boi
Joined Feb 10, '09
From pa
QUOTE (bmj67 @ Nov 12, 2009 - 6:50 PM) *
I can just use the high temp lock tight right?
Plus when i was changing the other plugs, the very first plug had just a very little bit of oil on it, should i pull that tube as well and reseal it?
BABI BOI
post Nov 12, 2009 - 8:19 PM
bmj67
Joined Oct 23, '08
_
This post has been edited by bmj67: Nov 12, 2009 - 11:45 PM
post Nov 12, 2009 - 10:22 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
NO -- DO NOT use FIPG or any other valve-cover goop on the spark plug tube threads.
The proper sealant is high-temp thread locker (blue) or teflon tape. This is on the threads, not the valve cover or the rubber seals
post Nov 12, 2009 - 10:55 PM
bmj67
Joined Oct 23, '08
3. INSTALL SPARK PLUG TUBES
(a) Clean the cylinder head tube holes of any residual adhesive,
oil or foreign particles. Remove any oil with kerosene
or gasoline.
(b) Screw the threads of the spark plug tube coated with
adhesive into the cylinder head.
© Using the spark plug tube nut and a 30 mm socket
wrench, tighten the spark plug tubes.
Torque: 39 N·m (400 kgf·cm, 29 ft·lbf)
right from BGB the adhesive they say to use is
Adhesive:
Part No.08833-00070, Adhesive 1324,
THREE BOND 1324 or equivalent
post Nov 12, 2009 - 11:14 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Could you please link to the appropriate BGB page, this would be the first time I've seen such a recommendation for the 5SFE and the threaded plug tubes. I have seen that for pressed-in tubes, but not the 5SFE's threaded ones.
This post has been edited by Galcobar: Nov 12, 2009 - 11:21 PM
post Nov 12, 2009 - 11:42 PM
bmj67
Joined Oct 23, '08
http://www.camrystuff.com/manuals/Gen4/Eng...chanical_I4.pdf
thats the page i was looking at and the only adhesive i saw was the 1324
post Nov 13, 2009 - 12:13 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Ah, EM-53.
If you look over the preparation section of the manual you'll note the adhesive section contains three items.
08826–00080 Seal Packing Black or equivalent (FIPG)
08833–00070 Adhesive 1324, THREE BOND 1324 or equivalent
08833–00080 Adhesive 1344 THREE BOND 1344 LOCTITE 242 or equivalent
Loctite 242 is blue thread locker. Both of the Three Bond products mentioned are also thread lockers, rather than gasket seals.
post Nov 13, 2009 - 9:40 AM
babi_boi
Joined Feb 10, '09
From pa
Ok so now i know what to use to re-install the tubes. Should i remove the first tube and redo that one as well. When i changed the plug in the first spot there was a little oil on it. Not alot just very little.
BABI BOI
post Nov 13, 2009 - 8:49 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
if you're there then yes, reseal the tubes.
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 18th, 2025 - 9:11 AM
