> fs:Automotive Photography Rig, serious inquires only!
post Oct 27, 2009 - 7:06 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
im giving this up mainly because im starting to move away from automotive photography. you can get some super unique shots with this. Its a bit of a hassle to put on at first but once you get the hang of it its a breeze.
its a pinch rail mount. and it is perfect for our cars. we have a L shaped rail which gives the clamps extra support.
this is the carry case for it.
whats in the case
what goes where. each pole is numbered to let you know what goes where
******THIS IS THE PART THAT NEEDS TO BE RE-WORKED!!!!!!******
the angle part isnt 100% stable. i dont have the time to re-do it.
as it is you need to walk with it or it will tip to the side.
all it needs is a little bit more support at that joint.
pinch rail mounts and how they mount with the pipes
The pipes go completely under the car to the other side.
hence two mounts because it mounts on both sides
you cannot mount the camera on this rig without this
you can find it alot cheaper around the interwebs
and it doubles as a tripod and is basically an all around sick contraption!
http://www.bhphotovideo.com/c/product/3254...ic_Arm_Kit.html
$170+Shipping
i havent calculated shipping yet. id prefer local pickup. PA NJ MD whatever
any further questions lmk!
This post has been edited by Tigawoods: Oct 27, 2009 - 7:07 PM
エキサイティングカーレーシングチーム!
post Oct 27, 2009 - 11:34 PM
rj8807
Joined Nov 18, '08
From Woodstock, Maryland
ahh this would be SOO COOL to have. But just like you, I've decided to move away from automotive photography.
I'm guessing you photoshop the rig out of the pics?
95 Celica ST (currently in Motorsport Purgatory)
post Oct 27, 2009 - 11:46 PM
^ I was gonna ask the same thing. I see the 'spot' now in the second pic, right to the left of the tire.
post Oct 28, 2009 - 12:50 AM
96bluevert
Joined Mar 19, '07
From Washington
Yes you photoshop the rig out.
I'd be all over this too if I hadn't just spend a bunch getting the car running. kindasad.gif
Bump for a good guy! (and another blurple Celica wink.gif )
post Oct 28, 2009 - 7:45 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
you get some unique shots with it i just cant deal with it
it helps you brush up on your skills. and as u can see. i havent used ps in that way for a long time.
a kit lens for slr cameras 18-55 is good for this
a 10-22 would be even better
anything above 20mm is too close to fit the whole car
エキサイティングカーレーシングチーム!
post Nov 18, 2009 - 9:40 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
bump
エキサイティングカーレーシングチーム!
post Nov 18, 2009 - 2:38 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
bump.. just cause i always wondered how you got those awesome shots!!
Lo-Fi Version Time is now: December 4th, 2024 - 1:18 PM
