> 7afe turbo question
post Nov 18, 2009 - 2:06 PM
st18
Joined Nov 20, '07
From Oil City Louisiana
i was planing on turboing my celica and i had a few questions before i do so.
1. has any one put a tubo on an automatic trans and can it handle it?
2. which is better duel or single bov?
3. what kind or brand of engine management should i use?
4. how much boost can the stock internals hold?
post Nov 18, 2009 - 3:58 PM
1. OOBE's '94 ST is turbo'd and automatic. Depends on how much power you're putting through it, it can handle it. He's reached 240 WHP, although it wasn't sustained.
4. Depends on the turbo, but again, OOBE is running (I think) 10-12 PSI on a T3/T4. Hafkai is running 12 PSI.
This post has been edited by SwissFerdi: Nov 18, 2009 - 3:58 PM
post Nov 18, 2009 - 5:50 PM
FunkySR
Joined Apr 22, '07
From Buckinghamshire, UK
I have a 7afte manual running 10 psi on a stock engine with AEM management.
post Nov 18, 2009 - 9:14 PM
CelicaST_CALI
Joined Feb 28, '07
QUOTE (st18 @ Nov 18, 2009 - 11:06 AM) *
1. has any one put a tubo on an automatic trans and can it handle it? depends on a lot of things,tranny wear,power #s,the way u drive ...no one has TRUELY tested it though
2. which is better duel or single bov?Single on a small engine setup like this
3. what kind or brand of engine management should i use?depends on power goals
4. how much boost can the stock internals hold?10 psi
BANNED. for life, you moron.
post Nov 18, 2009 - 9:16 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
yea.. theres a million variables to consider. I believe shannon blew a 5s-fe tranny at 5psi yet jeff run a 5s-fe @ 12psi? could be more.... on an auto for over a year just fine
This post has been edited by Mstoochn: Nov 18, 2009 - 9:17 PM
post Nov 19, 2009 - 3:03 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (FunkySR @ Nov 18, 2009 - 2:50 PM) *
what AEM? are you using the FIC? what are you using for injectors?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 19, 2009 - 3:18 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
First mod for your transmission should be to fit a good transmission cooler as the auto transmission is cooled by the engine radiator and so the fluid is always at engine water temp. Fit a small engine oil cooler intead as a transmission cooler with an inline oil stat set to about 60° centigrade. This will help the transmission to run cooler and last longer.
This post has been edited by jeffrosie: Nov 19, 2009 - 3:19 PM
post Nov 19, 2009 - 8:57 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
So far I haven't noticed my tranny slippin' or anything. It behaved awesomely in the dyno after many, many pulls and same on the road. I am very eager to hear it slip once I take it to the dyno again and crank up the boost, LOL.
post Nov 21, 2009 - 3:27 PM
FunkySR
Joined Apr 22, '07
Yes. I have rthe FIC with Supra 315cc injectors. These will be for sale soon as I now have a set of 360cc injectors.
post Dec 5, 2009 - 4:06 PM
burningice1989
Joined Dec 5, '09
From Harlingen, tx
For my personal question...
i have a 97 ST with the 7afe and i would like to turbo mine too.... but what would be the best fix for managing the fuel for the mix? i have heard of just swaping fuel pumps and injectors. but then again, i also heard you could just reprogram the ecu to remap the flow.
post Dec 6, 2009 - 1:35 AM
Mstoochn
Joined Apr 27, '09
QUOTE (burningice1989 @ Dec 5, 2009 - 4:06 PM) *
....thread jacking?
post Dec 6, 2009 - 2:19 AM
CelicaST_CALI
Joined Feb 28, '07
QUOTE (burningice1989 @ Dec 5, 2009 - 1:06 PM) *
How would u go about reprogramming the ecu,and physically i think the 7afe injectors and fuel pump are to small to deliver adequate fuel ..
This post has been edited by CelicaST_CALI: Dec 6, 2009 - 2:19 AM
post Dec 6, 2009 - 10:52 AM
burningice1989
Joined Dec 5, '09
From Harlingen, tx
Maybe I'm mistaken on the programing part. I think i read it off of some online article... But the article was more about general cars not just celicas. The celi proly does have inadequate pumps and injectors. So I guess I'll just have to switch it all. But I'm wodering if the same engine corolla turbo kit will work on my celi?
post Dec 9, 2009 - 8:03 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
QUOTE (burningice1989 @ Dec 6, 2009 - 7:52 AM) *
There is no bolt-on kit for the ST, you could get a 7afe corolla kit but you'd have to modify it to fit.
post Aug 24, 2012 - 8:31 PM
danillo
Joined Aug 8, '12
From Belem, PA, Brazil
QUOTE (FunkySR @ Nov 18, 2009 - 6:50 PM) *
Could you please share the AEM model of EMS, wiring diagrams and your 7AFTE setup? ThANKs
post Jun 20, 2013 - 1:11 PM
sherwin03
Joined Jun 20, '13
From philippines
i also have a 7afe coil type engine, im also planning to put turbo, but also worry to damage my engine, because the engine internal parts are all stock, is any one hir already made this kind of mode, putting turbo on stock 7afe, i hope you can help me, thanks, btw, im from philippines
post Jun 22, 2013 - 9:47 AM
QUOTE (sherwin03 @ Jun 20, 2013 - 2:11 PM) *
yes.
they all eventually blow up, just a matter of how long they last, and how much fun the person had while it lasted.
post Jun 23, 2013 - 2:00 PM
sherwin03
Joined Jun 20, '13
From philippines
QUOTE (presure2 @ Jun 22, 2013 - 10:47 AM) *
yes.
thank you sir, but im wodering, some one post from hir puting up turbo in his celica, if he replace internal parts of his engine, or he just put straight the turbo kit without replacing internal parts. thanks
post Jun 23, 2013 - 3:10 PM
it'll really depends on your goals, and how much your willing to spend to get it to run properly.
if its maintained properly, and most importantly tuned correctly, a properly built 7afte will last a good long while, even with stock internals.
i made 300+whp with my 5sfte a handful of years ago now, on a stock bottom end, and blew it with my half assed tuning.
just a matter of building it right, and tuning it properly, no matter the engine.
post Jun 24, 2013 - 5:41 AM
most importantly listen to podcast 1
Lo-Fi Version Time is now: November 23rd, 2024 - 12:38 PM
