97 ST Celica 02 Sensor wires, Can't find them |
Nov 18, 2009 - 11:06 PM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
I was wondering if anybody knew what the colors of the wires are for a 97' 7afe 02 sensor that bolts onto the header. Where are the wires run? I attempted putting a Celica back to stock (modified by previous owner) and I can't find the 02 sensor or the wires/harness to plug a sensor into. I did find 2 wires in the engine bay that look like they have been cut and have been thinking it's possible that those wires could be the ones I need. Thanks.
Nov 19, 2009 - 3:31 PM |
bump
Nov 19, 2009 - 10:16 PM |
Nov 19, 2009 - 10:56 PM |
Could you tell me what color the wires are after the harness? I see the blue and white wires for the sensor, are the wires that are covered up the same? Where do they run to?
Nov 20, 2009 - 12:15 AM |
i don't know for the celica, thats not a celica. but the clip should look the same and be in the same area.
Nov 20, 2009 - 12:30 AM |
Enthusiast Joined Nov 8, '08 From Penn Valley,Ca Currently Offline Reputation: 1 (100%) |
You are going to need four wires two four the oxygen sensor heater circuit and then signal and ground I think. In the morning I will look at my car however it is a GT so they could be different.
Nov 20, 2009 - 12:44 AM |
i don't know for the celica, thats not a celica. but the clip should look the same and be in the same area. Thanks, but the car seems to be missing the clip/harness completely. You are going to need four wires two four the oxygen sensor heater circuit and then signal and ground I think. In the morning I will look at my car however it is a GT so they could be different. The new sensor I got only has 2 wires on it. When I went to plug it in, I noticed that there was nowhere to plug it into. -------------------- |
Nov 20, 2009 - 12:47 AM |
Well good luck, the connector and wiring could be a pain to replace
Nov 21, 2009 - 4:16 PM |
Bump
Nov 22, 2009 - 10:54 AM |
post pic of the conector, as i have a few laying around, but it comes from a gt harness, may be the same.
Nov 22, 2009 - 7:29 PM |
post pic of the conector, as i have a few laying around, but it comes from a gt harness, may be the same. But that's my problem, I can't find the connector . -------------------- |
Nov 22, 2009 - 8:46 PM |
Catch22 for the win!
Nov 23, 2009 - 9:15 AM |
I mean the o2 sensor you have
Lo-Fi Version | Time is now: January 15th, 2025 - 1:53 PM |
