Enthusiast ![]() ![]() Joined May 28, '09 From Milwaukee, WI Currently Offline Reputation: 0 (0%) ![]() |
so I have a 94 celi and my interior lights are not working along with my cigarette lighter etc. I have looked at fuses and I can not find the problem. Has anyone had this problem before. Or is it a fuse somewhere that i am not finding..... Some body help me it's getting irritating to me
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '07 From Portland, Oregon Currently Offline Reputation: 67 (96%) ![]() |
check the fuse to your dome light, it's probably out. You'll find it in the relay box in the engine compartment, the black box near the air intake box. The lid is labeled on the underneath side with what fuse is for what. I believe the dome light (also is for your clock, does your clock work?) fuse is the third one in from the left, 2nd row. But check the lid.
Enthusiast ![]() ![]() Joined Jan 22, '07 From Loveland Currently Offline Reputation: 4 (100%) ![]() |
Could just be the bulbs too if you already checked fuses and an independant issue with the lighter. Lighter and radio are on the same circuit (I believe), so if the radio is good I'd still double check that fuse, but then I'd investigate the lighter and bulbs.
But just to rule out the door switch. Is it the entire dome light that's out? As in if you open the doors (Both passenger and driver), does the light come on or not come on? Or does nothing at all come on? |
Could just be the bulbs too if you already checked fuses and an independant issue with the lighter. Lighter and radio are on the same circuit (I believe), so if the radio is good I'd still double check that fuse, but then I'd investigate the lighter and bulbs. But just to rule out the door switch. Is it the entire dome light that's out? As in if you open the doors (Both passenger and driver), does the light come on or not come on? Or does nothing at all come on? Nothing works inside at all except the radio and dash lights |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) ![]() |
so,courtesy lights(door lights),dome light are both out?
-------------------- BANNED. for life, you moron.
Enthusiast ![]() ![]() ![]() Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) ![]() |
Any new electronics put in, or electronics rewired in lately? Also, sometimes the fuses won't look blown but can still be bad, best to change em out just in case.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) ![]() |
had the exact same problem after i installed my radio, i blew the dome fuse in the engine bay relay box, it took me like 2 days to realize it too, but if its all that and your door chime does not work than it is the dome fuse under the hood
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
alright guys I am going to check out those things you all mentioned. get back with you shortly...
Enthusiast ![]() ![]() Joined Mar 19, '09 From Malden, MA Currently Offline Reputation: 2 (100%) ![]() |
I think I know which one you're having trouble with, I think I had the same problem. It's in the panel under the steering column, it's labeled like something weird. I can't remember the name of it. Check all of them that you REALLY don't know what they go to.
I think I know which one you're having trouble with, I think I had the same problem. It's in the panel under the steering column, it's labeled like something weird. I can't remember the name of it. Check all of them that you REALLY don't know what they go to. If I remember correctly its a 7.5 and it's on either the top or 2nd row(closest rows to the steering wheel) -------------------- |
Lo-Fi Version | Time is now: February 20th, 2025 - 12:34 AM |
