> Interior Lighting, converting to LED's
post Nov 24, 2009 - 3:52 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Want info on converting interior lights - climate control button lights, to LED's.
Looks like there are already LED's in there but they are green. Want to change them to blue and red.
Anybody done this, is the voltage already stepped down for the LED's??
post Nov 24, 2009 - 5:01 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I'm pretty sure no one's ever done this before, you'd be the first.
post Nov 27, 2009 - 1:51 PM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
It will most likely be already regulated to handle led lamps. It would just be a matter of removing the green ones and soldering on new ones.
Once you get in there though make sure they are actually LED lamps and not just standard 12V lamps
ST205 Crew represent
Challenge Accepted
post Nov 27, 2009 - 4:56 PM
Ruroniarc
Joined Mar 19, '09
From Malden, MA
Many people have done this, and I've done it too. The bulbs behind there are standard 3v LEDs. I put blue ones behind there.
Be careful though, the lenses are green, so the blue light comes out a slightly different color. But, it's nice and easy, and desolder the old ones, and resolder the new ones. You'll want to get 3mm lights and not 5mm lights, and you'll probably have to file them down on the edges to make them fit, I just used a piece of sand paper.
The other bulbs in there that provide the backlight are 12V bulbs, and you'll need to use a resistor in there.
post Nov 27, 2009 - 7:40 PM
jeffrosie
Joined Sep 11, '08
post Jan 8, 2010 - 10:16 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
QUOTE (jeffrosie @ Nov 27, 2009 - 7:40 PM) *
Did you end up doing this? pics would be nice!:D
post Jan 8, 2010 - 10:49 PM
bmj67
Joined Oct 23, '08
hate to tell you but the stock bulbs to backlight the climate control are 12v the indicator lights themselves are set for led though its not just a simple 10 min job to change the color. This is my climate control
post Jan 10, 2010 - 6:31 AM
RoyO
Joined Jan 8, '09
From Netherlands
Nice job! What bulb is installed behind the sigarette lighter?
post Jan 10, 2010 - 9:40 AM
bmj67
Joined Oct 23, '08
Those are leds not a bulb
post Jan 10, 2010 - 9:43 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
i sell these... check the for sale section
Breaking Axles...
post Jan 10, 2010 - 3:18 PM
bmj67
Joined Oct 23, '08
nice thread jack pitt haha and you dont sell that exact one cause that one has my panel on it tongue.gif the lighter led i wouldnt recommend doing if you use the actual cigarette lighter because it can heat up too much and may start a fire.
post Jan 10, 2010 - 7:10 PM
RoyO
Joined Jan 8, '09
From Netherlands
QUOTE (bmj67 @ Jan 10, 2010 - 4:40 PM) *
What leds are installed behind the sigarette lighter?
post Jan 10, 2010 - 7:16 PM
bmj67
Joined Oct 23, '08
just regular blue leds but you cant wire them directly in they will just burn out you have to use resistors to drop the voltage
post Jan 11, 2010 - 4:23 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
QUOTE (jeffrosie @ Nov 24, 2009 - 9:52 PM) *
No problem with that... you just need some experience with that to avoid re-modifing it many times beforre it will look really good...
a) green LEDs (they are on when button is active only) is just direct swap... but... you have to find small enough round LEDs (3mm) or square LEDs to fit. Also is recomended to not using high illuminated LEDs for this (if you try you find why smile.gif)
b) bulb replacenet is bit more complitaded because bulb has wider angle beam than LEDs -> you may expect darker and lighter sports using LEDs. To minimize that is essential using high illumination LEDs. Plus you must use proper resistors or LEDs will burn (usual working voltage for LEDs is 3.5-4.5V)
Lo-Fi Version Time is now: February 21st, 2025 - 6:02 AM
