Transmission on reverse, Kind of weird. |
Nov 27, 2009 - 5:56 PM |
Enthusiast Joined Nov 27, '09 From Canada Currently Offline Reputation: 4 (100%) |
Hi again everyone. Ok this may sound weird but at certain occasions when I put it in reverse, after I start backing up a little a big thud sound kicks in. It sounds lik I hit something underneath my car. Anyone have an idea on what it might be? Thanks again for the help. It's much appreciated
Nov 27, 2009 - 6:23 PM |
Enthusiast Joined Jun 18, '08 Currently Offline Reputation: 3 (100%) |
You should check the fluid level make sure you got fluid and also make sure you not leaking anything. Im assuming its automatic. Does it only make this sound when you throw it in reverse? Also does it make this sound as soon as you put it in reverse? or afterwards. The driveshafts ???????
This post has been edited by Tech-Nics: Nov 27, 2009 - 6:25 PM |
Nov 27, 2009 - 7:02 PM |
I'm sorry. I know it's stupid but I don't know how to check the tranny fluid level. I have an st model 94. And the car is standard by the way. It doesn't make the thud right when I put it in reverse. But after I start backing up. Sorry I don't know about cars so I don't really know what a driveshaft is
Nov 27, 2009 - 8:33 PM |
Enthusiast Joined Nov 4, '09 From Sacramento, California Currently Offline Reputation: 0 (0%) |
Not to be rude goonter but, when he says words you don't know, try googling them or dictionary.com or howstuffworks.com.
I like howstuffworks.com because they helped me great understand the basics of cars, which if you are trying to find out what a problem is its a great way to start. And its simple. But try to look for what Tech-nics sayed online and see if thats the problem. -------------------- Brand new 6gc owner! (sort of 2011)
The world is moving around a sun, the sun moves around a local arm of the galaxy, the local arm of the galaxy moves around a gigantic black hole. |
Nov 27, 2009 - 9:12 PM |
no not rude at all.. and thank you for the advice and site link.. i appreciate it good sir
Nov 28, 2009 - 12:38 AM |
to check the fluid on the manual tranny there is no dipstick, you have to pretty much put the car on a level plane, and unscrew the top or filler bolt on the tranny and see if the fluid is about to overfill, pretty much stick your finger or a plastic to find it, or fill it with oil until it tops out
Nov 28, 2009 - 1:07 AM |
Enthusiast Joined Mar 19, '09 From Malden, MA Currently Offline Reputation: 2 (100%) |
It's your drum brakes. Get them checked / replaced ASAP, because they will lock up soon.
By the way, this only happens in reverse because of the auto-adjust feature that drum brakes have on them, when they're messed up like they are, the auto-adjust feature just breaks them worse, instead of fixing them. |
Nov 29, 2009 - 12:37 PM |
the drum brakes i see.. how much do you think it would be to replace the drum brakeS?
Nov 29, 2009 - 12:59 PM |
Enthusiast Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
You can get a pair of drum brakes from your local autoparts store for $15-30 complete cost.
Nov 29, 2009 - 1:30 PM |
You can get a pair of drum brakes from your local autoparts store for $15-30 complete cost. that would be just the drums or just the shoes. he'll need drums AND shoes as well as the springs/hardware. those should be replaced when replacing shoes, springs wear. -------------------- |
Nov 29, 2009 - 2:01 PM |
you could just get the disc conversion done in the back. not hard and not too expensive.
Nov 29, 2009 - 2:31 PM |
anyways, i doubt brakes. sounds more like motor mount maybe.
Nov 30, 2009 - 4:21 AM |
wait what?.. why th emotor mount?
Dec 1, 2009 - 3:20 AM |
Enthusiast Joined Aug 12, '08 From Paterson nj Currently Offline Reputation: 0 (0%) |
I have a 94 st hatch back, but automatic and I'm interrested in you idea, how much you think the kit costs and some suggestions where can I buy the complete diskbrake kit? for both sides, dont try to estimate the mechanics job too, just the disks, thanks in advance
QUOTE you could just get the disc conversion done in the back. not hard and not too expensive.
This post has been edited by SinisterSinner: Dec 1, 2009 - 3:21 AM -------------------- waiting for LEDs for next project WOW recieved the LEDs, just tested a set up on a breadboard and I can barely see anything lol. I think I'm closer to being blind !! |
Dec 3, 2009 - 4:32 AM |
I have a 94 st hatch back, but automatic and I'm interrested in you idea, how much you think the kit costs and some suggestions where can I buy the complete diskbrake kit? for both sides, dont try to estimate the mechanics job too, just the disks, thanks in advance QUOTE you could just get the disc conversion done in the back. not hard and not too expensive. Theres some info on the site about what parts you'll need, its in the search area. Also, I believe there is a set up in the for sale thread out of someones car that hes parting on here..... That price was just for the shoes. And, the spring(and all the goodies) kit is another like 7-15 bux, and you don't need to buy new drums everytime, they are able to be resurfaced just like rotors, just did mine that way a couple months ago. -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 7:55 PM |
