Enthusiast Joined Jul 23, '09 From UK Currently Offline Reputation: 0 (0%) ![]() |
HI
anyone ever had any problems with the fuel release lever (down by the driver seat) mines gone really loose and is pulling to the right and not releasing the fuel cover had the carpet and everything up but I cant really get to it. Ive had the panels out in the boot to try and get to the cable from that end but cant find it anywhere. is there an easy way to fix. or has anyone made a mod for this so u could have a motorised release switch or something? |
Enthusiast Joined Sep 2, '09 From greenock Currently Offline Reputation: 0 (0%) ![]() |
to get at the lever mate you need to take the drivers seat out and lift the carpet, once your in there is a bolt holding it in place, once you undo that bolt the levers pull out from behind, (on my car this is what was broken) to get the cable out completly you need to take of the boot lining to show the bottom of the ariel (fuel release mechanism is behind it - pop the cable out of the holding at this end and then change your levers (as they fall apart)
good luck and only reason i know is i spent 2 hours yesterday....yes yesterday figuring all that out |
Thanks, i thought someone would have had the same issue.
from what i could feel (couldn't really see too well) i think the bolt has come loose. Guess Ill have another go next weekend and take the seat out. When i was trying to find it at the boot end i did notice that my aerial seems to be letting in water, guess Ill have to try and replace that at some point as well. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
I have fuel door and trunk release buttons because my lever was broken, tricky to install the solenoids but once you figure it out its pretty cool
![]() -------------------- Mike W
where about did you install the solenoids?
I've seen plenty of kits for the trunk door and thought i could just use one of them to do it. |
Remove the boot liner plastics, Theres a hole there where you can feel the fuel door locking mechanism, unhook the nipple on the original cable from the locking mechanism and figure out your own drawstring and solenoid mounting location. May take a full day to figure out.
Enthusiast Joined Apr 7, '14 From ireland Currently Offline Reputation: 0 (0%) ![]() |
to get at the lever mate you need to take the drivers seat out and lift the carpet, once your in there is a bolt holding it in place, once you undo that bolt the levers pull out from behind, (on my car this is what was broken) to get the cable out completly you need to take of the boot lining to show the bottom of the ariel (fuel release mechanism is behind it - pop the cable out of the holding at this end and then change your levers (as they fall apart) good luck and only reason i know is i spent 2 hours yesterday....yes yesterday figuring all that out Hi, I have this exact problem and im going to attempt to fix it myself this weekend. I am a female 6th generation ss3 owner and have never tried anything like this before. I have had a look and it's def the cable that's broken. I have the new one ready to install and I've looked online to find some kind of instructions and this seems like the most detailed. When I remove the seat and lift the carpet, after removing the old one, should the new one be easily routed back into place? I'd really appreciate any help I can get.. Thanks! |
Lo-Fi Version | Time is now: February 19th, 2025 - 11:35 PM |
