> my car broke last night., burst pipe?
post Nov 29, 2009 - 3:28 PM
ajmorris1977
Joined Jul 13, '09
last night i was driving home from work when i got some straem from under the hood, i stopped and looked to find there was the noise of hissing and steam comming from behind the motor (2.2 gt) on the passenger side, is there a heater hose back there? what could it be do you think? none of the guages read hot so i hope its not a head gasket or something, stressing myself out over this as i cant afford a huge bill right before christmas...thanks.
You're here for a good time, not a long time. - Colin McRae
When in doubt... Flat out! - Colin McRae
Understeer is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you....
post Nov 30, 2009 - 4:23 AM
trdproven
Joined Aug 2, '05
From Guam
there is a coolant hose on the passenger side. perhaps even a heater hose for coolant. but then again even if it was that you would be loosing coolant. You can most likely tell its a head gasket because if you look in your coolant it will look mixed with oil and vice versa. But hissing sound sounds more like coolant because of the water and because oil won't make that loud sound. Id check for coolant leaks.
This post has been edited by trdproven: Nov 30, 2009 - 4:24 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Nov 30, 2009 - 10:14 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
you only get the mixture in the oil if it pushes coolant into the oil most of the time you just push combustion pressure in the coolant making it overheat.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: January 13th, 2025 - 2:58 AM
