> ride height
post Dec 5, 2009 - 11:11 PM
Ted95
Joined Mar 8, '09
From Westport, MA
hey guys, so i want to lower my celi to get a better lookin stance bc to me the stock stance looks sooo tall, and im told that KYB shocks and struts with Eibach springs is good for my 95gt. im jus wonderin if i should go with a 1 inch drop or 1.5 or w.e.. lookin for some opinions and wonderin how smooth my ride will be, dont want it to be really bumpy, hoping it wont be.
lemme kno what u think,
thanks
st205 powered ss3 coupe
post Dec 6, 2009 - 1:37 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
Tein SS coils.... expensive but well worth it, -2.5, +2.25 of adjustablility
Its a sporty ride but its comfortable.... your rubber will have a big effect on how stiff the ride is (if u go below a 45 tire, or use a vr series)
post Dec 6, 2009 - 9:09 AM
pipes
Joined Apr 23, '08
From boston MA
post Dec 6, 2009 - 9:50 AM
trdproven
Joined Aug 2, '05
From Guam
you don't need a bigger tire for comfort you can also compensate instead of 45 series you can get like a 225 for example. My 225 looks the same or bigger than a 45 series tire. its all in combination.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 6, 2009 - 1:20 PM
Ted95
Joined Mar 8, '09
From Westport, MA
well i planned on keepin my stock tire and rim bc i painted my rims and im happy with the way they look and to me its alot cheaper bc i dont have the money to go out and buy nice rims and tires. so idk if that would make a difference, cuz the set up i was gunna go with was prob gunna run me around 400, 200 for shocks and 200 for the struts and shocks.. i wasnt sure how far down i should go with it, and will it effect my gas milage lowering my car?
post Dec 6, 2009 - 2:20 PM
^ There are NO shocks on our cars, only MacPherson struts all around. I've found the fronts for 50 each and the rears for 58 on Amazon. Springs will run you around 200, so it should be around 420 in total. thumbsup.gif
This post has been edited by SwissFerdi: Dec 6, 2009 - 2:21 PM
post Dec 6, 2009 - 2:28 PM
Mstoochn
Joined Apr 27, '09
you could convert to superstrut tongue.gif GOODLUCK!
post Dec 6, 2009 - 2:42 PM
ajmorris1977
Joined Jul 13, '09
i went with a 5" drop and my ride is really bumpy, but i think it looks great!!!!
You're here for a good time, not a long time. - Colin McRae
When in doubt... Flat out! - Colin McRae
Understeer is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you....
post Dec 6, 2009 - 6:38 PM
trdproven
Joined Aug 2, '05
From Guam
can I see your 5" drop, that sounds ridiculously low.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 6, 2009 - 7:00 PM
ajmorris1977
Joined Jul 13, '09
QUOTE (trdproven @ Dec 6, 2009 - 7:38 PM) *
this is her with a four inch drop....
but i am droppeing her another inch today so i'll get pics on here tomorrow when i get her back on the ground...
post Dec 6, 2009 - 7:01 PM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
QUOTE (SwissFerdi @ Dec 6, 2009 - 2:20 PM) *
Its still a shock lol, its just inside the strut.
but yeah I have eibach pro-kit, a good spring but the back is still way too high, you need atleast 1.5 drop in the rear I think and 1 drop in the front.
post Dec 6, 2009 - 7:37 PM
epocsirhc
Joined Nov 8, '08
From Penn Valley,Ca
That yellow celica is goint to look sick with a five inch drop.
post Dec 6, 2009 - 7:57 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (ajmorris1977 @ Dec 6, 2009 - 7:00 PM) *
clean ride, but doesn't it annoy you sometimes with the car that low?
post Dec 6, 2009 - 9:21 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Looks fine, but you can't take a sloped driveway, speed bumps, debris in the road, etc.
OP- A popular combo on here is KYB GR-2 shocks (entire rear assembly, shock inserts in front) with Tein S-tech springs. 1.5" drop in front, and 1" in the rear. It sets the car up with an aggressive looking stance.
Presure2 has the sportline springs, which are reported at 1.5" all around.
Look through the member's ride section and see what you like.
**** Photobucket
post Dec 6, 2009 - 9:40 PM
QUOTE (95CelicaST @ Dec 6, 2009 - 9:21 PM) *
More on this...why not do the entire assembly all around? Reason I'm asking is because I'm about to purchase that.
post Dec 6, 2009 - 9:54 PM
flyinglizard
Joined Nov 15, '08
From Merced, CA
QUOTE (SwissFerdi @ Dec 6, 2009 - 9:40 PM) *
This is the same thing I did. Just the shock absorber inserts for the front and entire assembly for the rear. Cheaper that way.
post Dec 6, 2009 - 9:58 PM
Cheaper, yeah...but wouldn't it be better to play it safe?
post Dec 6, 2009 - 10:02 PM
flyinglizard
Joined Nov 15, '08
From Merced, CA
QUOTE (SwissFerdi @ Dec 6, 2009 - 10:58 PM) *
The shock is the only moving part in the strut assembly. You aren't cutting any corners by just getting a new insert.
post Dec 6, 2009 - 10:04 PM
Okay, that makes sense. So why not get only the inserts all around, and skip the assembly in the rear as well?
post Dec 6, 2009 - 10:07 PM
flyinglizard
Joined Nov 15, '08
From Merced, CA
QUOTE (SwissFerdi @ Dec 6, 2009 - 11:04 PM) *
Both the front and rear have wet struts with integrated shocks. The difference between the two is that the fronts have a big retaining nut, allowing you to remove the shock pistons and put new inserts in. The rears don't have the retaining nut, everything is permanently intact.
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: December 4th, 2024 - 7:06 PM
