3 Pages V  < 1 2 3 >
> 3D speedometer console
post Dec 14, 2009 - 10:18 AM
Can you post more specifications concerning the materials, i.e. size/diameter of the piping? A run to a hardware store should get me all of those items, and If I can find a spare gauge trim, I'm down to try this.
This post has been edited by SwissFerdi: Dec 14, 2009 - 10:19 AM
post Dec 14, 2009 - 11:14 AM
blu94gt
Joined Mar 23, '05
From Kansas City
Wow I remember seeing the old Doggy ones YEARS ago and thinking they were cool...I think I have myself a winter project after I'm done with finals this week.
1999 Celica GT
post Dec 16, 2009 - 2:09 PM
tomazws
Joined Oct 30, '04
From So Cal
I have to say this is ****ing BEAUTIFUL! Awesome work!
post Dec 26, 2009 - 1:28 PM
RoyO
Joined Jan 8, '09
From Netherlands
QUOTE (SwissFerdi @ Dec 14, 2009 - 5:18 PM) *
I'll measure everything next week!
I just cut new glass and i'm going to install 25% light transmission film at the glass. 50% film was too dark.
This post has been edited by RoyO: Dec 26, 2009 - 1:35 PM
post Dec 26, 2009 - 2:06 PM
richee3
Joined Jun 29, '08
From Denver
25% film will make it darker than 50%. Just so you don't end up buying something and making it darker when you want it a little lighter. This turned out really well though. I'm liking it.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Dec 26, 2009 - 6:56 PM
RoyO
Joined Jan 8, '09
From Netherlands
QUOTE (richee3 @ Dec 26, 2009 - 9:06 PM) *
I know what you mean, thnx smile.gif .. Police calls that film 75%, window tinting shops calls the same film 25% over here.. wink.gif
post Dec 30, 2009 - 5:53 AM
RoyO
Joined Jan 8, '09
From Netherlands
The glass thickness is 4mm
1=93mm (inside)
2=90mm (inside)
3=28mm
4=50mm
5=3mm
I'm going to reinstall de console next week and i'll post new pics tongue.gif
post Dec 31, 2009 - 1:32 PM
Driveby
Joined Sep 17, '05
From Newcastle / UK
Great work mate, gives it a nice high end look.
1994 JDM GT4 WRC
post Jan 1, 2010 - 10:39 AM
RoyO
Joined Jan 8, '09
From Netherlands
Tellerconsole is completed.
Old glass (in the middle) with 50% film, new glass (left and right) with 25%...
Special thanks to Work4Poop for the carbon fiber instrument cowl!
-Roy
post Jan 1, 2010 - 12:05 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
Edit: Next post has the full materials and tools list.
A how-to guide would be awesome.
This post has been edited by BloodyStupidDavey: Jan 1, 2010 - 4:15 PM
post Jan 1, 2010 - 3:01 PM
RoyO
Joined Jan 8, '09
From Netherlands
You also need polyester putty to fill holes.
(Not yet polished over here)
I think this is a complete list of everything needed.
Material:
-OEM Console
-2x grey plumbing reducing collars
-2x white plumbing end cowls
-4mm clear plastiglass
-SL Llumar film 25%
-Water/ lather to install film on glass
-Polyester putty
-Plastic primer
-Primer
-Color
-Clear varnish
-Bison hard PVC glue
-Black glue to glue glass into console
-Benzine to degrease before spraying
Tools:
-Dremel with plastic cutting disc
-Electric jigsaw to cut the glass
-Files
-Rulers
-Sandpaper 150 - 1200
-Heat gun to install 25% film
-3m foil applicator
-Bench drill 5mm
-Cutter
-Tape
This post has been edited by RoyO: Jan 1, 2010 - 3:05 PM
post Jan 2, 2010 - 10:17 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
it's bit different but result is quite good anyway...
here with gauges...
and illuminated (red-white LEDs inside)
Just glass is missing. I bought transparent 2mm thick polystyrene but it's too fragile for fabrication (cutting is horrible) so now looking for soft plastic (better cutting material)
post Jan 2, 2010 - 12:26 PM
why dont you guys send a prototype to vincent dogy to get it fiberglassed.
post Jan 2, 2010 - 12:52 PM
RoyO
Joined Jan 8, '09
From Netherlands
QUOTE (malpaso @ Jan 2, 2010 - 5:17 PM) *
Well done Malpaso! Cutting the glass and installing the film is the hardest part of the job smile.gif
You could fill the gap between pipe and OEM frame with polyester putty...
By night/ evening, the tube in the middle of my 3D console looks very cool.
(plumbing reducing collars)
The part in front is narrower then the part behind so you get a special effect when you look into it!
post Jan 2, 2010 - 1:35 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Amazing work!
Now make one for a SW20
**** Photobucket
post Jan 2, 2010 - 2:15 PM
I'll buy one if you guys make it.
post Jan 2, 2010 - 3:52 PM
celiracer
Joined Oct 5, '05
From NE
I'd buy one too For sure.. That looks amazing.
post Jan 2, 2010 - 5:10 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
i will buy one too
2001 Solar yellow Lexus IS300
post Jan 3, 2010 - 2:32 PM
ajmorris1977
Joined Jul 13, '09
QUOTE (SwissFerdi @ Jan 2, 2010 - 3:15 PM) *
x2, i'm just not that good at getting things perfect like this, how much?
You're here for a good time, not a long time. - Colin McRae
When in doubt... Flat out! - Colin McRae
Understeer is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you....
post Jan 3, 2010 - 5:25 PM
love it!
Only thing I would do is maybe sand the paint with 2000grit and try to polish it to give it a smoother look.
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: January 10th, 2025 - 7:47 PM
