> wtb pwr stering (thing) and other (things)
post Dec 7, 2009 - 7:37 PM
Dragondog
Joined May 10, '07
From Lubbock, Texas
on my pwr ster pump thers a cap that has two lines that connect to it the cap busted so now thoes two lines just hang there......i dont know what it is r whats used for.....i went to az to see if they had and they dont know whut it is........also i have a senser on my block under the intake that i need to replace........and also a vaccum part 2 lines run to it they r for the charcle canister it screws in on this coolent housing next 2 2 other sensors one being a temp sensor the houseing is next to the distributor....thx
feedback
feedback
If I buy or sale please leave me feedback...thanks
cheap, quick, reliable, pick two
I treat my 6gc better then my own woman
post Dec 7, 2009 - 7:52 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
i couldn't follow half of that but i have all of those parts
the power steering guy is the idle up valve... not really needed but you need to cap those lines if it broke otherwise you will have a huge vacuum leak... PM me an offer for all the parts... i have them all
EDIT: second sensor is the knock sensor... those are hella expensive so keep that in mind... third sensor is the vacuum switch... i DO NOT have that... mine broke as well and can only be found on celicas before 96... you can find it on any 5sfe before 96, check junk yards
This post has been edited by pittfirefighter: Dec 7, 2009 - 7:54 PM
Breaking Axles...
post Dec 7, 2009 - 8:11 PM
Dragondog
Joined May 10, '07
From Lubbock, Texas
if the the pwr stering valve is not nessisary then ill pass on that unless i can get it from you for a low price.........the knock sensor i dont know how much they run so i dont know what to base it off of......my hopes were to get these parts under 50$....or all three for 50$....but let me know whut you can do...your knock sensor is it original? chiped? cracked? brittle?
This post has been edited by Dragondog: Dec 7, 2009 - 8:47 PM
feedback
feedback
post Dec 7, 2009 - 8:53 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE (Dragondog @ Dec 7, 2009 - 9:11 PM) *
i don't use the vacuum assist on my turbo car so i can sell you that for cheap... i can do knock alone for $40 or both for $50... knock runs around $150 new... mine is stock in working condition... they are either working or not... they don't go bad over time... not brittle either..
Breaking Axles...
post Dec 7, 2009 - 9:11 PM
Dragondog
Joined May 10, '07
From Lubbock, Texas
thats what happend to mine is it got brittle and the platic just crumbled............yes 50$ for both i will do
feedback
feedback
post Dec 8, 2009 - 10:06 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
PM me, i will grab pictures of the parts to double check
Breaking Axles...
Lo-Fi Version Time is now: December 4th, 2024 - 5:16 AM
