Can I remove my Cruise Control Assembly?, I hope I posted this in the right area |
Dec 10, 2009 - 6:04 PM |
Enthusiast Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
I was wondering how or if I can even remove my cruise control. I don't have the cap that covers it and it rattles to the point that it drives me crazy. I have plenty of time on my hands now that school is out, and I really want it out of there. I cut the wires when I installed my new steering wheel, so I know it is at least safe enough to have that control switch removed for it. But I want the hole dang thing out of there!
-------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Dec 10, 2009 - 6:18 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
yes you can. i took mines out when i dropped the trans. IIRC 2 plugs, undo the linkage that controls the speed, and 3 bolts should be under the battery. -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Dec 10, 2009 - 6:50 PM |
Enthusiast Joined Nov 30, '04 From Atlantic City Currently Offline Reputation: 21 (100%) |
where do you hide the linkage?
Dec 11, 2009 - 1:39 PM |
Enthusiast Joined Apr 17, '07 From Montreal, QC, Canada Currently Offline Reputation: 1 (100%) |
You cut it at the firewall and then from the inside, pull it and cut the excess.
That's what I did on mine when I installed my CAI since it was in the path -------------------- |
Dec 11, 2009 - 7:25 PM |
Enthusiast Joined Jan 17, '09 From Hilo Hawaii Currently Offline Reputation: 0 (0%) |
i just unclipped mine not a problem
Dec 15, 2009 - 7:39 PM |
Doesn't it go to the throttle though? When I pull the cable it moves the throttle. I am a little scared to remove it seeing that. Is it really just as simple as "unhook" and be done?
Dec 15, 2009 - 7:59 PM |
it moves the throttle because when you engage the CC it pulls and holds the throttle pedal I dunno about cutting it though I'd just find a way to tuck it.
Dec 15, 2009 - 8:08 PM |
Enthusiast Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
its a simple unclip on the ends of the cable... don't cut the cable... its really not that tough
-------------------- Breaking Axles...
Dec 15, 2009 - 9:43 PM |
its a simple unclip on the ends of the cable... don't cut the cable... its really not that tough Yup exactly -------------------- |
Dec 16, 2009 - 12:14 AM |
it moves the throttle because when you engage the CC it pulls and holds the throttle pedal I dunno about cutting it though I'd just find a way to tuck it. Cool. But where do I unhook it from beyond the firewall? I just see it on the module in the engine bay. -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Dec 16, 2009 - 2:19 AM |
dont do disconnect anything under your dash, just under the hood, your not going to notice a differant if you dont use your cc
Dec 16, 2009 - 4:03 AM |
dont do disconnect anything under your dash, just under the hood, your not going to notice a differant if you dont use your cc Ok thanks, I will do it tomorrow then. Thanks everyone. Ok it is removed... Now I can get rid of it. This post has been edited by Random_Stranger: Dec 16, 2009 - 7:04 PM -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Lo-Fi Version | Time is now: January 9th, 2025 - 1:42 AM |
