> ST205 catalytic converter, Is there a difference
post Dec 12, 2009 - 6:52 AM
Davis_2
Joined Sep 8, '08
From Ireland
Is there a difference between st185 and an st205 converter as they are the same in shape and bolt up mainly the internal lay i need to know as i have just Failed emissions (head wrecked) and everything else is fine no leaks but timing slightly off.
post Dec 12, 2009 - 2:38 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Should fit, but you may have 1 stud on exhaust side of turbo unsed.
post Dec 15, 2009 - 12:25 PM
Davis_2
Joined Sep 8, '08
From Ireland
QUOTE (jeffrosie @ Dec 12, 2009 - 2:38 PM) *
Oh no fits perfect to be honest have it on already. The thing is my car failed emission so im wondering would the inside of the cat be differrent to manage different fuel load for each model of celica or would they be the same. Its was .4?? on CO levels timing is off so think thats whats causing it.
post Dec 15, 2009 - 12:39 PM
Random_Stranger
Joined Mar 20, '07
From Bakersfield, CA
WTF? You guys have emissions out there too? At least I know who I can get the converter from now when I get my front clip now. Guess I should renew the membership at ol GT4oc.
post Dec 17, 2009 - 4:35 AM
Davis_2
Joined Sep 8, '08
From Ireland
Yeah they are starting to get strickter on it and increasing tax on cars that have larger engines.
www.camskill.co.uk good for service parts
www.fensport.co.uk good for aftermarket parts
Don't know if they ship that far though.
post Dec 17, 2009 - 7:54 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
If your CO was high and the other two readings were low (not even just passing, but well within specs) then take a look at your O2 sensor. If your timing is off, that might also produce much the same results as a rich AFR, which can also produce a high CO reading.
post Dec 18, 2009 - 9:48 AM
Davis_2
Joined Sep 8, '08
From Ireland
QUOTE (Galcobar @ Dec 17, 2009 - 7:54 PM) *
Redoing the timing now having bother with the timing belt though just changed it and now rubbing off the engine and buring so getting hole new kit as i think one of the pullies are off. Will check the sensor though could well be it.
post Feb 1, 2010 - 8:32 AM
Davis_2
Joined Sep 8, '08
From Ireland
Just an update for all the car past the test. Stupid leak at a join caused it. Now to put on the decat wink.gif
Lo-Fi Version Time is now: November 24th, 2024 - 6:36 PM
