> Camry Sport Pedal Cover, Wondering if anyone has installed these before....
post Dec 12, 2009 - 4:00 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Did a search, couldn't find a thing. So I figured I'd ask if anyone has installed these things before. Here are a few pics---->
I plan on doing this in a few hours...but if anyone has prior experience that would be great.
Thanks.
This post has been edited by Spider77: Dec 12, 2009 - 4:01 PM
post Dec 12, 2009 - 4:30 PM
nice, too bad is for an auto, how much is the damage?
post Dec 12, 2009 - 4:54 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
I know I know...auto. But the car was free, so I couldn't say no to that! Um, it cost me about 40 shipped (off ebay) from some guy in Canada.
post Dec 12, 2009 - 7:41 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Okie...so it appears there needs to be some slight modifications made in order for these to fit. The brake pedal has to be shaved down a bit (on all 4 sides), but that's not that big of an issue. The gas pedal for some odd reason is made of plastic....I dont know what they were thinking when they did that. Besides the obvious shaving of some plastic, I wanted to get some guesses on how to help these pedals stay put. I was thinking something like epoxy, but wanted to see if anyone else had a better idea.
post Dec 14, 2009 - 10:22 PM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
I would be tempted to take the rubber off the stock pedals and rivet these on. I would love a pair of these if I could find them in manual
ST205 Crew represent
Challenge Accepted
post Dec 15, 2009 - 6:56 PM
so any updates?
post Dec 15, 2009 - 7:23 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Yeah. I had to go out and finally get a dremel because i didnt feel like manually filing down the pedals. Turns out im missing like 5 attachments. Before I break in the rotary tools Im awaiting some kind of response from the company. On the plus side it looks like it'll be pretty easy with the dremel, got that and some rubber-metal bonding agent just to keep the pedals on there. I really like the "billet" look (specially with the laser etched toyota) so plan on keeping them on there. On the side though been looking for a similar dead pedal. But as soon as I get this done (hopefully this weekend) I will post results.
post Dec 16, 2009 - 12:40 AM
trdproven
Joined Aug 2, '05
From Guam
they are usually screws looks like rivets but in the back side there are threads that hold the back side with a piece of metal that grabs/wraps the pedal. At least that is how aftermarket auto pedals ive seen are mounted. In fact i had one set before.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 16, 2009 - 6:12 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
most of them do. the aftermarket ones i took off did. these have lips on the back to slip over the pedal.
post Dec 16, 2009 - 12:56 PM
tomazws
Joined Oct 30, '04
From So Cal
post Dec 16, 2009 - 6:00 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
QUOTE (tomazws @ Dec 16, 2009 - 1:56 PM) *
Thanks, CastrolCelica did this one up for me so I cant really take credit! I like it too, its pretty much what I wanted.
post Dec 17, 2009 - 7:32 AM
cyprus_gt
Joined Jan 16, '09
From Cyprus
Mate can you make some photos when you finish the modification and some words about the pedals
thanks
Happy Christmas
cheers
post Dec 17, 2009 - 7:27 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Yeah. Im going to try and do this on the weekend here..while the temp still holds out!
post Dec 20, 2009 - 3:33 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
OK, so the weather held out and it was a nice day to get this done.
As you may know I had to make some modifications to the stock pedals to get these to fit properly.
By far the brake pedal was the easiest. More room to work with and its metal (not plastic). The cover was made to slide right over the camry pedal with little to no effort. In this case though the sides had to be ground down. That was easy enough with a dremel.
This is with the sides ground down and a little bit of Loctite metal/rubber adhesive. I placed the glue in the two grooves running the length of the pedal and slid it on.
This is the brake pedal cover all clamped down.
This is the backside of the gas pedal cover next to the stock pedal. As you can see there isn't much for it to grab on to, and some cutting had to be done. Dont have any pics of that, but pretty much had the make the pedal thinner and curve the edges. Other than that, the only problem was the rubber tabs didn't slide into place under the pedal, as there are parts of it that get in the way and do not allow for this to happen. What I had to do was at least get the top and bottom corners to slide under. After I got that all set up I slathered the pedal and the back of the cover with the adhesive and slipped it on. After a bit of struggling (the adhesive made it a little slick) I clamped the hell out of it.
So, now that is how its sitting. In a few hours I will go out, take off the clamps and run some more adhesive on the back side and sides of the covers to assure that they stay in place. All in all, the gas pedal was the worst. Im sure the brake pedal will stay put, but untill I allow it to dry and get out there and use it, I cant say if the gas pedal will meet my expectations.
post Dec 26, 2009 - 12:16 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Ok, so its been close to a week now. Well, the pedals have stayed put. Its a nice look (one of which I need to clean up a bit), but the only downside (going from "smooth" pedals to pedals with nubs) is I cant move my toes once I have the pressure applied. Which Im still getting used to. All in all, it looks 100% better than those blue anodized/cf "look" I had.
post Jan 7, 2010 - 7:48 AM
cyprus_gt
Joined Jan 16, '09
From Cyprus
QUOTE (Spider77 @ Dec 26, 2009 - 7:16 AM) *
Nice work man!
can you give me the part number of the pedals and how much did you pay for them?
thanks
Cheers
post Jan 7, 2010 - 8:36 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
the PN is in the first pic. I got them off ebay for about 40 bucks. But remember these are for an AT. The sellers name is hotshotmikey... he might have some extras.
post Jan 8, 2010 - 10:08 AM
cyprus_gt
Joined Jan 16, '09
From Cyprus
QUOTE (Spider77 @ Jan 8, 2010 - 3:36 AM) *
Thanks mate
i contact the seller but he don't have.... but will go to toyota dealer with the part number to check..
I also have pedals to my auto celica but its cheap one - with these the car look nice
cheers
Dimitar
post Jan 8, 2010 - 7:55 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Just remember the stock pedals require a bit of modification to get these covers to fit. The gas pedal is the hardest though. Good luck. BTW, ive had these on for awhile now and they are holding up!
post Jan 25, 2010 - 9:27 AM
cyprus_gt
Joined Jan 16, '09
From Cyprus
So today i've been to toyota dealer in Cyprus and they don't find nothing with this part numbers that i get pfrom the picture!
i also check on 1sttoyotaparts.com and they don't have any parts on theyr data base...
any idea why?
Cheers
Lo-Fi Version Time is now: February 23rd, 2025 - 7:50 AM
