rear defroster not working, at all |
Dec 14, 2009 - 4:01 PM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
ok my rear defrost will not work at all, front works fine, but im wondering if they could of disconnected anything when they tinted my windows
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Dec 14, 2009 - 4:34 PM |
Enthusiast Joined Jun 18, '08 Currently Offline Reputation: 3 (100%) |
Did you use them since they tinted your windows? My wife's 96 takes for ever for the back to defrost. Mine on the other hand is good in minuets. It's certainly a possibility that they didn't reconnect them or the fuse or connection to the relay. Oh yeah I want to see some new pictures of your car too. Mine is at the shop for now. I'll get new pictures when I get it back.
Dec 14, 2009 - 5:09 PM |
Enthusiast Joined Aug 29, '09 From Ohio Currently Offline Reputation: 7 (100%) |
Do you hear the relay click on the driver side kick panel when you push the rear defrost button? Also you can put a multitester to the two connectors on the back window to see if they broke the defroster stripes on the back window. Also can disconnect the stripes (be really careful cause I broke one of the tabs off) and test to see if you get 8-12 volts to the back defroster stripes. If you break the connector or the stripes are cut then you are tough out of luck. Try this you tube link.
http://www.youtube.com/watch?v=rj7KH_PZn3c ok my rear defrost will not work at all, front works fine, but im wondering if they could of disconnected anything when they tinted my windows |
Dec 14, 2009 - 5:59 PM |
Did you use them since they tinted your windows? My wife's 96 takes for ever for the back to defrost. Mine on the other hand is good in minuets. It's certainly a possibility that they didn't reconnect them or the fuse or connection to the relay. Oh yeah I want to see some new pictures of your car too. Mine is at the shop for now. I'll get new pictures when I get it back. its not working at all which sucks, its cold as **** here in the winter, it was 5* here the other morning and couldnt see out the window untill about 30 minutes later from the heat in the car, sorry to hear about your car though what all did they say was wrong with it? and i keep forgetting to put my pics up lol i keep leaving my camera in the car, and ajlee i have not heard a click, but then again i never really was listening to for it, and do i have to take the plastics off the rear to access the plugs? -------------------- 1996 Toyota Celica Project Mean Green
Dec 14, 2009 - 8:08 PM |
Did you use them since they tinted your windows? My wife's 96 takes for ever for the back to defrost. Mine on the other hand is good in minuets. It's certainly a possibility that they didn't reconnect them or the fuse or connection to the relay. Oh yeah I want to see some new pictures of your car too. Mine is at the shop for now. I'll get new pictures when I get it back. its not working at all which sucks, its cold as **** here in the winter, it was 5* here the other morning and couldnt see out the window untill about 30 minutes later from the heat in the car, sorry to hear about your car though what all did they say was wrong with it? and i keep forgetting to put my pics up lol i keep leaving my camera in the car, and ajlee i have not heard a click, but then again i never really was listening to for it, and do i have to take the plastics off the rear to access the plugs? Hey man not to thread jack, but since you asked. Turned out to be a cylinder was not firing. So I was running only on 3. Should be a easy fix. |
Dec 14, 2009 - 9:25 PM |
ah its cool lol, but the relay kicks on i can hear it ping, so im guessing its just the plugs, so im just gonna go to the tint shop tomorrow and raise cain till they decide to fix it ha ha, but great to hear your car is ok,
Dec 16, 2009 - 2:51 PM |
bump... i need help it is cold as **** in northern kentucky and i cant see when my rear window is frozen over
Dec 4, 2010 - 9:47 AM |
hate to bump an old thread but defrost is still not working, used a 12 volt tester, ya know clip one side on ground the other put the tip at the connection and it seems like the rear is not getting any power, help please? i can hear the relay kick so i assume its still good, can anyone help me out here.
EDIT: and after taking a look at my chiltons manual its not even mentioned in there... This post has been edited by 96stgreendemon: Dec 4, 2010 - 9:53 AM -------------------- 1996 Toyota Celica Project Mean Green
Dec 4, 2010 - 12:07 PM |
I have the same problem, but i havent tested mine. i hear the relay click as well, but it will heat up once in a blue moon
This post has been edited by mkernz22: Dec 4, 2010 - 12:08 PM |
Dec 5, 2010 - 5:44 AM |
bump for an update, im confused, i bought a multi-meter yesterday and started looking at the fuse in the fuse box in the dash and under the hood, all fuses look good, defrost fuse was tested and is fine. so i was thinking maybe there was a break in the lines, hook up the ohm setting on the multi meter and flows through fine, so im guessing that between the fuse and the glass its cut somewhere or im missing a fuse, but like i said the relay can be heard clicking on.
can someone please help me before i tear my interior out? -------------------- 1996 Toyota Celica Project Mean Green
Dec 5, 2010 - 5:46 AM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Start by removing the seats
dp |
Dec 5, 2010 - 5:19 PM |
Tore the entire dash apart, still no further than yesterday, guess pulling the rear seats tomorrow
Dec 6, 2010 - 10:30 PM |
Horray!!!!!!! finally figured out the problem, after tearing out the front seat, dash board, kick panels, rear plastics, rear seats and carpet.
the conection where the hatch lifts up the power wire looks like it literally caught fire in the conector, it was black and all melted together. pulled it out and soldered it back together and i have defrost now, and it only took 4 damn hours -------------------- 1996 Toyota Celica Project Mean Green
Feb 13, 2013 - 5:13 PM |
Enthusiast Joined Feb 22, '04 From USA Currently Offline Reputation: 3 (100%) |
NEW BUMP! Is this a common problem with the celicas? I have the exact same thing with mine which i just found, the connector is melted and blackened. This seems like it is becoming a common occurence!
Feb 13, 2013 - 7:34 PM |
Common, no, but with aged wiring comes increased resistance, possible short circuits, and corroded connections. Like anything else, a little preventative maintenance can help; clean and protect connections, inspect wiring for breaks or damaged insulation and replace as necessary.
Feb 15, 2013 - 8:42 AM |
Enthusiast Joined Nov 24, '07 From Tucson, Az Currently Offline Reputation: 2 (100%) |
Oddly enough, mine hasn't worked for a few years (including the first couple of cold nights here) then suddenly it started working the other day... not sure what happened. I haven't done anything electrically to the car lately. I'll have to check the connect later on today.
Kevin |
Jun 12, 2013 - 3:49 PM |
Enthusiast Joined Mar 8, '05 From Louisville Currently Offline Reputation: 0 (0%) |
Where exactly is the connector?
Jun 15, 2013 - 12:40 PM |
Still need the know where the melted connector is bump
Lo-Fi Version | Time is now: January 10th, 2025 - 1:02 AM |
