Outline of new features for '96 model Celica, Changes from USDM '95 model to '96 |
Dec 15, 2009 - 1:44 AM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
Celica 1996 New Features
OUTLINE 1. Exterior Equipment - The design of the front bumper has changed. - The front turn signal has changed shape and the lens has been changed from amber to clear. - A three post spoiler design has replaced the two post spoiler design. - Sideskirts available as an option. 2. Interior Equipment - The seat slider handle for front seats has been changed to a "loop" type. - The amount of movement of vertical adjustment of the front seat cushion has been changed. 3. 7A-FE Engine - The components of the engine proper and engine control system have been partially improved. 4. 5S-FE Engine - The engine control system has been partially changed. - The diagnosis system conforms to the OBD-II requirements. 5. A140E and A246E Automatic Transaxles - The diagnosis system conforms to the OBD-II requirements. - When the ECM on the '95 Celica detects a malfunction in the electric circuit of the ECT (Electronically Controlled Transaxle), it warns the driver by turning on a MIL (Malfunction Indicator Lamp), and flashing the O/D OFF indicator light. However, the '96 Celica has been modified to turn on only the MIL. 6. Brakes - On models with rear disc brakes, the rear disc rotor thickness has been changed from the previous 10.0mm (0.394 in.) to 9.0mm (0.354 in.) to save weight. 7. Body - An impact absorbing structure for side collisions is newly adopted to comply with the new FMVSS214 regulations (for reducing the risk of serious and fatal injury to occupants). - The allocation of sound absorbing and vibration damping materials has been revised in order to reduce road noise. 8. Air Conditioning - The variable volume control mechanism in the compressor has been discontinued on the 5S-FE engine, automatic transaxle models. - A defroster-linked air conditioning startup control has been added to automatically engage the air conditioning when the defroster mode has been selected. 9. Cruise Control - The control methods for the manual and auto cancel functions of the cruise control ECU have been changed. 10. Wiper - The method of operating the wiper lever has been changed on all models. IN-DEPTH DESCRIPTION OF NEW FEATURES W/ PICTURES Exterior Equipment 1. Front Bumper, Front Fog Light, and Front turn Signal Light The redesigned front bumper contains a bumper lower grille and front fog lights that convey a powerful, high-performance image. In addition, the front turn signals light lens has been changed from amber to clear. 2. Rear Spoiler A wing type design has been adopted to give the rear spoiler a wide and swift look. 3. Side Mud Guard (Side Skirts) A large side mud guard has been provided in the rocker area to give the Celica a more dynamic exterior design. The side mud guard is made of Toyota Super Olefin Polymer (TSOP), a material that is known for its light weight, damage resistance, and superior surface quality. In addition to protecting the body from the flying stones and sand, the side mud guard reduces the sound made by stones and sand hitting the rocker area. Interior Equipment 1. Front Seat A loop-type slide handle has been adopted for ease of fore-and-aft slide adjustment. - The height of the edge of the cushion, as the seat cushion is moved from the lowermost to the uppermost position, is lower than that of the '95 model. Thus, the infringement of the cushion seat surface against the driver's thighs has been minimized. As a result, the driver's access to the clutch and accelerator pedals has been improved, without being affected by differences in individual, physical charateristics of drivers. 7A-FE Engine 1. The 7A-FE engine in the '96 Celica has an increase in torque in the low to medium speed range and increase in fuel economy. Performance Curve 1. Major Differences The 7A-FE engine of the '96 Celica differs from the '95 Celica in the following areas. Engine Proper- Low-tension type piston rings are used. Intake and Exhaust Sytem- An EGR pipe is built into the intake manifold. In addition to making the port sections of the intake manifold smaller and the port lengths longer, the intake air chamber volume and shape have been changed to flatten the torque characteristics in the practical speed range. Valve Mechanism- The timing of the intake and exhaust valves has been changed, and the intake valve lift amount has been changed from 7.6mm (0.30 in.) to 7.4mm (0.29 in.) Ignition System- The igniter, which was previously integrated with the distributor, is now separate. Emission Control System- The TWC (Three-Way Catalytic Converter), which was previously installed below the exhaust manifold, has been discontinued. 2. Engine Control System General The following changes have been made to the engine control system. SFI (Sequential Multiport Fuel Injection)- 1. The fuel injection system is changed from the 2-group type MFI system to a sequential multiport fuel injection type SFI system. 2. A heated oxygen sensor (Bank 1, Sensor 2) is used. 3. Instead of using the IDL signal input from the throttle position sensor, the ECM now uses the VTA signal to detect the completely closed state of the throttle valve. 4. A crankshaft position sensor is used on all models. Accordingly, the Ne pick-up coil in the distributor has been discontinued. IAC (Idle Air Control)- The VSV for air conditioner idle-up has been discontinued, so the idle speed is controlled by the IAC valve only. Diagnosis- 1. The diagnosis system conforms to OBD-II. 2. The EGR gas temperature sensor has been discontinued. The new 7A-FE engine uses a signal from the manifold absolute pressure sensor (PIM) to detect any malfunctions in the EGR system. 5S-FE Engine 1. Engine Control System General The following changes have been made to the engine control system. SFI (Sequential Multiport Fuel Injection)- 1. The fuel injection system is changed from the 2-group type MFI system to a sequential multiport fuel injection type SFI system. This system has already been adopted to California specification models. 2. Instead of using the IDL signal input from the throttle position sensor, the ECM now uses the VTA signal to detect the completely closed state of the throttle valve. 3. A crankshaft position sensor is used on all models. Accordingly, the Ne pick-up coil in the distributor has been discontinued. IAC (Idle Air Control)- The VSV for air conditioner idle-up has been discontinued, so the idle speed is controlled by the IAC valve only. Fuel Pressure Control- The fuel pressure control system has been discontinued, so the VSV for fuel pressure control has also been discontinued. Diagnosis- 1. The diagnosis system conforms to OBD-II. 2. The EGR gas temperature sensor has been discontinued. The new 5S-FE engine uses a signal from the manifold absolute pressure sensor (PIM) to detect any malfunctions in the EGR system. Body 1. Impact Absorbing Structure The body shell contruction of the '96 model has been modified as described below. - A center pillar reinforcement connecting the lower part of the center pillar and center floor cross member is adopted to ensure a high level of center pillar strength. - An energy absorbing pad and rib are provided at the upper shoulder and lower arm rest areas of the door trim and the quarter trim to ensure a high level of energy absorbent for side collisions. 2. Sound Absorbing and Vibration Damping Materials The quality of sound absorbing and vibration damping materials has been revised, and the application of these materials has been expanded, in accordance with the vibration characteristics of the various areas of the body. The resultant decrease in the road noise level enhances the vehicle's quiet performance. Wiper 1. General The operation method of the washer function (squirting of the washer fluid and 2 wipes of the windshield) has been changed from pushing the washer button at the end of the lever to pulling the lever backward to improve the ease of use of the wipers. The mist operation (windshield single sweep) and washer button have been discontinued accompanying this change. This post has been edited by MaskedMan: Dec 15, 2009 - 2:58 AM -------------------- |
Dec 15, 2009 - 2:23 AM |
Nice writeup
-------------------- Mike W
Dec 15, 2009 - 2:56 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
amazing... Perfect to the letter!
-------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
Dec 15, 2009 - 9:19 AM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
nice ha ha, just thought i would point out that a very rare number of cars in 96 came off the line with the facelift bumper and a 2 post spoiler like mine, although it was a 2 post it was not compatible with the gt4 blocks, which screwed me up ha ha
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Dec 15, 2009 - 10:00 AM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
wow, didn't know there was so many differences. thanks. and i only thought it was the facelift bumper that was different.
-------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Dec 15, 2009 - 2:35 PM |
Enthusiast Joined Mar 19, '07 From Washington Currently Offline Reputation: 9 (100%) |
Great write-up!
Most of this stuff you wouldn't really even notice between the two unless you were looking closely. -------------------- |
Dec 15, 2009 - 2:39 PM |
nice ha ha, just thought i would point out that a very rare number of cars in 96 came off the line with the facelift bumper and a 2 post spoiler like mine, although it was a 2 post it was not compatible with the gt4 blocks, which screwed me up ha ha I just did the conversion from 3 post to 2post gt4. What did you find incompatible? I shaved off some studs on the bottom of my gt4 spoiler. -------------------- Mike W
Dec 15, 2009 - 4:11 PM |
Enthusiast Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
Awesome post - one of the best this year!
Interior Equipment 1. Front Seat A loop-type slide handle has been adopted for ease of fore-and-aft slide adjustment. On UK models, the facelift driver's seat retains the small lever and lumber adjustment. nice ha ha, just thought i would point out that a very rare number of cars in 96 came off the line with the facelift bumper and a 2 post spoiler like mine, although it was a 2 post it was not compatible with the gt4 blocks, which screwed me up ha ha Yea, the switch from pre-facelift to post-facelift wasn't instant some late '95 and early '96 cars seem to have a mix of equipment. A couple of things that I don't think were mentioned above (although I might have missed them): 1. Slightly different manifold and heatshield design on the facelift 3SGE engine 2. Different seatbelts 3. Tinted facelift window glass is pale green (except moonroof, which retains blue tint), while pre-facelift is darker and has a blue hue [*1] 4. Facelift ABS is now all-four wheels where fitted [*2] 5. 3rd brakelight [*3] 6. Twin airbags *1 - Some Celicas have clear glass. I think this is always pre-facelift and US (perhaps Canada) only *2 - Pre-facelift sometimes had 2-wheel ABS (servos). I assume the sensors were also 2-wheel. Not sure whether there are any 4-wheel pre-facelift ABS Celicas or not. *3 - facelift have cyclops brakelight on the tailgate lid. Not sure whether it is missing on all pre-facelift or whether it varied from country to country on pre-facelift but in Europe all facelift cars have the 3rd brake light. This post has been edited by BloodyStupidDavey: Dec 15, 2009 - 4:23 PM -------------------- Davey
Items for sale |
Dec 15, 2009 - 4:34 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
Good stuff Derrick
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Dec 15, 2009 - 4:36 PM |
Enthusiast Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
Excellent work Derrick! But.......... you got too much time on your hands. LOL jk
-------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Dec 16, 2009 - 10:10 PM |
Thanks guys! And thanks for all the added information too! I'm still researching more information. I'm going to try to do one for every year from 95-99 to see what new features were available. I figured that 95-96 was the biggest change to the 6th gen, so I did that one first.
Dec 17, 2009 - 12:17 AM |
Enthusiast Joined Jul 9, '08 From California Currently Offline Reputation: 5 (100%) |
Thanks guys! And thanks for all the added information too! I'm still researching more information. I'm going to try to do one for every year from 95-99 to see what new features were available. I figured that 95-96 was the biggest change to the 6th gen, so I did that one first. What about '93-'94? -TC -------------------- Live your life for yourself. Don't hold back for anything or anyone.
Dec 17, 2009 - 12:20 AM |
Enthusiast Joined Apr 17, '07 From Montreal, QC, Canada Currently Offline Reputation: 1 (100%) |
I goota say that I prefer the 2 posts spoiler... 96+ reminds me of the 5th gen
Dec 17, 2009 - 1:02 AM |
Thanks guys! And thanks for all the added information too! I'm still researching more information. I'm going to try to do one for every year from 95-99 to see what new features were available. I figured that 95-96 was the biggest change to the 6th gen, so I did that one first. What about '93-'94? -TC I could, but that's boarder line off-topic haha. I would just be describing the awesomeness of the 6th gen, and it wouldn't be a very useful post I goota say that I prefer the 2 posts spoiler... 96+ reminds me of the 5th gen Most people like the look of the 2 post over the 3 post as well. -------------------- |
Dec 20, 2009 - 6:34 AM |
Thanks guys! And thanks for all the added information too! I'm still researching more information. I'm going to try to do one for every year from 95-99 to see what new features were available. I figured that 95-96 was the biggest change to the 6th gen, so I did that one first. 95 - 96 had some minor changes and facelifts, but I believe 97 - 98 (JDM) was the one for the major changes. Projector headlights, Beams engine, All interior that changed between 95-96 has changed again between 97-98 (And more), More OEM bodykit for the SS-III including the return of the WRC high 2post spoiler for SS-III and GT-Four. -------------------- Mike W
Dec 20, 2009 - 6:39 AM |
Why is your car listed as GT-Four?
As far as I know no ST205 rolled off the production line with a coupe rear end, a soft top, FWD and FE motor? This post has been edited by delusionz: Dec 20, 2009 - 6:40 AM -------------------- Mike W
Jun 5, 2014 - 12:00 AM |
can this be stickied please!
Sep 1, 2015 - 4:06 PM |
Bump for Justin
Sep 4, 2015 - 11:47 AM |
Mods please sticky this one!
Lo-Fi Version | Time is now: November 26th, 2024 - 3:28 AM |
