> Oil pan, Oil pan removal
post Dec 15, 2009 - 4:25 PM
Maxtumare
Joined Jul 16, '08
From miami, fl, usa
I need to replace my oil pan Gasket. How would I go about removing the oil pan? has a write up been made for this? Because I see in a lot of different sites that I'm going to have to jack up the engine. Is there another way?
post Dec 15, 2009 - 4:26 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
once you jack up your car you can see how it comes off.
post Dec 15, 2009 - 4:38 PM
Maxtumare
Joined Jul 16, '08
From miami, fl, usa
I have jacked it up, there are all sorts of obstacles in removing it. I'm thinking I'm just going to remove things until I have a clear path for the pan, but I was just curious if there was a better way.
post Dec 15, 2009 - 4:40 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
lolz, I always have that problem with this car. it has a funny way of getting in my way.
post Dec 15, 2009 - 4:42 PM
trdproven
Joined Aug 2, '05
From Guam
Theres usually just one way. Taking it out is an obstacle but putting it back is another. You would have to cross tighten, proper torque (i'd use a socket screwdriver to put back the bolts quickly first). Are you planning to use RTV only or just a gasket? Proper torque and tightening technique is the key. btw why would you need to change that?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 15, 2009 - 4:48 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
the only thing that should be in your way may be your exhaust... i think it can still come off without touching the exhaust.. its just a bunch of 10mm bolts and a few 10 mm nuts... do not put a gasket on it, it will just leak... use toyota fipg...
Breaking Axles...
post Dec 15, 2009 - 5:32 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
QUOTE (pittfirefighter @ Dec 15, 2009 - 5:48 PM) *
i am also going to be doing the same because i have oil leaking from there. excuse my noobness, but what is a toytoa FIGP?
post Dec 15, 2009 - 5:42 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
lol its TOYOTA FIPG... FORM IN PLACE GASKET... like RTV but a little higher quality, comes in a white tube for about $8 if i remember right
Breaking Axles...
post Dec 16, 2009 - 2:09 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
QUOTE (pittfirefighter @ Dec 15, 2009 - 6:42 PM) *
thank you very much sir.
post Dec 16, 2009 - 4:23 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
i got mine off with just removing the plastic skids. hardest part was cleaning the area up cuz they leak like MF'S. dont use too much fipg!!
Lo-Fi Version Time is now: January 8th, 2025 - 10:27 AM
