> UPDATEE!!!Car wont start.. fuel pump??
post Dec 18, 2009 - 9:34 PM
Ted95
Joined Mar 8, '09
From Westport, MA
k soo heres the story.. as of right now, my car sits in the garage at maaco because it wont start.. over the past 2 weeks my car has had some trouble starting up in the morning and at night. i would start it and it would stall out instantly.. i would do it again and rev it to like 2500-3000rpms and hold it, it would sputter a bit and then smooth out.. i was thinkin it was just because it was cold out idk.
motor has 200k on it btw
so today my mechanic (manny if ur reading this it was Johnny) picked up my car to replace my axels and then im guesssssing decides to take it for a joy ride because he ran out of gas as he was bringing the car back.. i met him and put gas in the car and it wont start.. turns over with NO PROBLEM and with plenty of juice to the battery.. we tow it back to maaco and put it in the garage and i finally got it started but as soon as i give it gas it GAGS hardcore! so its obv not gettin enough fuel to the engine im guessing ..
so does anyone else think it could b that or somethin else.. please help! lol i miss my celi already
UPDATE*********
k so after 3 machanics and about $250 later my cat is FINALLY fixed and running betttter then ever.. turns out my distributor was bad but that is now replaced and all timed out and runnnning great.. im soo happy lol after 2 weeks of driving my moms camry (2.4 vvti .. wasnt to bad) i was soooo excited to get behind the wheel of my 5s again biggrin.gif biggrin.gif biggrin.gif biggrin.gif biggrin.gif biggrin.gif biggrin.gif biggrin.gif omg the sound of my exhaust (and now hallowed out cat.. thats another story) was like an orgasim to my ears lol.. anyways thats the good news.. next mission is to paint my valve cover and order my TRD spoiler biggrin.gif biggrin.gif biggrin.gif
This post has been edited by Ted95: Jan 7, 2010 - 1:38 PM
st205 powered ss3 coupe
post Dec 18, 2009 - 11:46 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (Ted95 @ Dec 18, 2009 - 10:34 PM) *
yep, he probably ran it dry.... when the pump isn't lubricated it doesn't make long before it fails
This post has been edited by Mstoochn: Dec 18, 2009 - 11:46 PM
post Dec 19, 2009 - 7:35 AM
camron, take a short peice of wire, and in your diagnostics box, bridge the FP and B+ pins with the car in the on position.
you should be able to feel fuel running thru the return line, and in the line from the fuel filter to the rail.
if you dont, the pump is bad.
post Dec 19, 2009 - 12:43 PM
Ted95
Joined Mar 8, '09
From Westport, MA
k thanks manny
post Dec 19, 2009 - 12:55 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
QUOTE (presure2 @ Dec 19, 2009 - 8:35 AM) *
no, if you don't then the fuel pump is not running. could be an electrical issue. need to confirm both good power and ground at the pump before condemning it.
post Dec 19, 2009 - 1:30 PM
DGAF
Joined Nov 27, '09
From New York USA
You could also try to remove the fuel cap and put your ear in the hole and have somebody turn the ignition switch on. You should be able to hear the fuel pump run for about two seconds and then stop.
If this is OK. then have your friend crank the engine momentarily. you should be able to hear the pump work again.
post Dec 21, 2009 - 12:16 AM
trdproven
Joined Aug 2, '05
From Guam
car won't start is based on mostly ignition or fuel. igniter, distributer, fuel pump, etc.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 21, 2009 - 12:53 AM
Mstoochn
Joined Apr 27, '09
if its not the fuel pump, check the fuel pressure regulator, if it fails u wont get enough fuel to the injectors UNLESS U FLOOR IT.
and u no if u turn the key to the "ON" position you will hear the pump turn on...
This post has been edited by Mstoochn: Dec 21, 2009 - 12:54 AM
post Dec 21, 2009 - 5:30 AM
acidice333
Joined Nov 7, '09
From Victoria BC
Could it not be the EFI Water Temp sensor too?
If it went out, and its cold, then it would be somewhat hard to start and also the car would die/sputter when you gave it gas until it was like 2k RPM.
post Dec 21, 2009 - 5:52 AM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (Mstoochn @ Dec 21, 2009 - 3:53 PM) *
toyota fuel pumps are pretty quiet though.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 22, 2009 - 4:55 PM
Ted95
Joined Mar 8, '09
From Westport, MA
so far it still ****s the bed.. we replaced the plugs and fuel filter. the cylinder head was flooded and tryin to clean that out but still when it runs and u give it gas, it gags out.. im gunna check the vaccum lines tomorrow.. hopefully its that =/
post Dec 22, 2009 - 5:15 PM
Have you guys checked timing yet?
post Dec 22, 2009 - 5:24 PM
Ted95
Joined Mar 8, '09
From Westport, MA
not yet.. idk why it all of a sudden just stopped working.. retard johnny ran it out of gas and god knows wat he did with it b4 it ran out but it wont start since he ran it dry.. and he blew my dad off again so im pissed, butch is pissed tim is pissed.. like he broke my car and walked away from it.. hes a ****in doushe.. we r checkin some more stuff tomorrow, ill give a update.
post Dec 22, 2009 - 8:22 PM
Bitter
Joined Mar 11, '06
QUOTE (Ted95 @ Dec 22, 2009 - 6:24 PM) *
post Dec 23, 2009 - 9:40 PM
Ted95
Joined Mar 8, '09
From Westport, MA
UPDATE- alright so heres todays update lol.. the car runs, but not very good.. its running way to rich because when i get on it my car back fires and blows out black smoke out of my intake.. yes my intake.. we ran a diognostics test or w.e it is and we found 2 codes, 24 and 31.. 24 being one of o2 sensors and 31 being the map sensor.. the toyota dealership or w.e toyota place we called said that the map sensor is $275 and it mighttt not be the problem.. it could be the EIG thing or w.e i cant remember then name but that cost 600-700$ !!! .. this sucks..
post Dec 25, 2009 - 12:38 PM
cameron, dont buy anything new from the dealer. just let me know what you need, i have a couple motor sets to take parts off of.
post Dec 25, 2009 - 9:45 PM
Ted95
Joined Mar 8, '09
From Westport, MA
sweet deal manny.. we r sendin it out tomorrow to get looked at again .. ill let u kno wat i may need. thanks manny
****** i mean monday not tomorrow lol
post Dec 26, 2009 - 2:19 AM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
My car would not start when cold because my coolant temp sensor melted inside somehow. Check it out to make sure it is good even if it looks good it could be bad.
post Jan 7, 2010 - 1:45 PM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (xrav22 @ Dec 26, 2009 - 2:19 AM) *
that sucks
Lo-Fi Version Time is now: November 30th, 2024 - 7:44 AM
