> Time for a new Project, DIY Garage Door Opener
post Dec 19, 2009 - 3:53 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
I found myself trying to find another simple yet very meaningful project for the celica when I came across an idea for a diy garage door opener that wires up to the batter while i was trying to open my damn garage door with the pos battery one in my car in 0 degree weather. I'll be following the guide of this DIY Garage Door Opener. I'll be sure to keep you all informed of how it all goes. I'm also going to throw a twist on the button that I think you'll all find very enjoyable wink.gif . I'm still in the process of measuring things out and finding the right parts. I should be done with it in the next 2weeks -1month depending on when the parts get in and when I have time to work on it.
post Dec 19, 2009 - 4:38 AM
too complicated...
http://www.6gc.net/forums/index.php?showto...amp;hl=homelink
stealth is the way to go man. No welding required...
post Dec 19, 2009 - 12:35 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
there's no welding required, just drilling and putting in new buttons, but I'm not doing this for the buttons like i said you're all going to like what I'm doing for the button. It requires no drilling and if it does work then I'm sure it will be copied by everyone on this site, which I have no problem with I just wanna be the test dummy and make the write up for it smile.gif. You may even change it.
post Dec 19, 2009 - 4:48 PM
That looks great, can't wait. I have two bulky clickers on my visor. kindasad.gif I've seen this done on an NC MX-5, it looked nice. For sure a good mod.
This post has been edited by SwissFerdi: Dec 19, 2009 - 4:49 PM
post Dec 19, 2009 - 5:00 PM
flyinglizard
Joined Nov 15, '08
From Merced, CA
Awesome. I'm definitely going to do this since I hate those ugly remotes on my visor.
post Dec 20, 2009 - 12:21 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
Bought one of these today, my plan is to take out the cig lighter and replace it with this. I got the far left one with the blue ring.
post Dec 20, 2009 - 11:48 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
QUOTE (freddy121389 @ Dec 20, 2009 - 1:21 AM) *
Those look nice, where did you come across these at?
post Dec 20, 2009 - 8:26 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Going by the image properties, I'm going to guess http://store.expressions-ltd.com, specifically http://store.expressions-ltd.com/servlet/-...on%2Cled/Detail
This post has been edited by Galcobar: Dec 20, 2009 - 8:39 PM
post Dec 27, 2009 - 7:01 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
alright i need help, it works great, i mounted the thing next to my gauge cluster under the center console and also wired the wires up to the first button, the button on the actual transmitter works and if i connect the wires it works but for some reason after i connected the wires to the button i purchased with the led on it it only works when i turn the key to on. I mean i understand its only making a connection when i turn the car on because i have the power and ground wired to the cig lighter wires. But the switch I have wired up is whats making it do it so I'm at a loss. Anyone help? I think i just make need to get a new switch.
post Dec 30, 2009 - 12:33 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
i can't follow your post at all.. i would be happy to help but its not making any sense to me at all... if its wired to the cig lighter... it won't work with the car off or acc
Breaking Axles...
post Dec 31, 2009 - 4:02 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
sorry let me re phrase, i bought a homelink garage door opener and mounted it inside my dash, but to access it outside of my dash i soldered wires to the to ends of a button on the circuit board on the homelink so that i may wire up an external button somewhere else. I purchased a button Here's the link to the button i bought, with only a + and - in and out where the wires would mount. Now i know it wont work with the car off since the cig lighter only works with the car on, but whats happening is when im wiring up those wires from the circuit board to the switch it automatically completes the circuit. The led illuminates, the switch is in the out or off position, so right when i complete the circuit the garage door opens and until i turn off the power and turn back on or remove a wire and reattach it, it doesn't work. Now I'm wondering can that led really pass enough current through it to cause the signal to go through. i talked to the company i bought it from and he said that it cant complete the circuit but im not entirely sure why it wouldn't anyone have any ideas to solve my dilema?
This post has been edited by freddy121389: Dec 31, 2009 - 4:04 AM
post Jan 1, 2010 - 3:33 PM
since you are running with the cig lighter, the make sure you have the dimmer controlon full, you are loosing power.
post Jan 1, 2010 - 5:25 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
QUOTE (njccmd2002 @ Jan 1, 2010 - 4:33 PM) *
how does this relate to my dilema? i completely took out my cig lighter
This post has been edited by freddy121389: Jan 1, 2010 - 5:30 PM
post Jan 1, 2010 - 9:19 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
It sounds like you've wired the switch sensor on the board to the LED circuit in the button, as opposed to wiring it to the switch circuit in the button.
However, that's based upon my having to interpret your post as your sentence structure and grammar make (or lack thereof) makes for an unclear post.
If you're saying the button you purchased has only the one circuit, then that makes sense if it's an interrupt -- as in pressing the button interrupts the circuit. Rather like the button on your car doors, whereby closing the door cuts off the power to the interior lights.
As for njccmd2002's post, he's pointing out that the power you're drawing off the cigarette lighter wiring is adjusted by the dimmer switch. It's the power to the wiring that is affected, which is what you've accessed.
post Jan 2, 2010 - 12:42 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
im trying to be as clear as i can, i even sent a link to the actual button im using to be more precise. I soldered in 2 wires into the two sides of one of the buttons for the homelink so that i may wire an external button else ware. so the button i purchased only has 2 connectors in the back for 2 wires + and -. When i have it hooked up the led comes on and when i push it in the led turns off. But no matter what the circuit stays closed causing the garage to open immediately once i turn my car on. And why is the cig lighter controlled by the dimmer i really dont understand, i keep it on full all the time but what reason is there to make the cigarette lighters power to dim?
post Jan 2, 2010 - 12:54 AM
sorry got confused, tought it wass the cigarrette light and not the lighter, which is not dimmed
the button you installed has an LED? right? the led is drawing the power and not making the unit work. try a button with no led.
post Jan 2, 2010 - 3:16 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
but i want the led one because it looks awesome, he's sending me a new one where the led and button are separate so im pretty sure the led was closing it, now ill wire up the cig light to the led light, so it only comes on at night.
post Jan 2, 2010 - 4:19 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Try detaching the button, and test what happens when you simply cross the leads off the HomeLink switch.
post Jan 2, 2010 - 7:23 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
the garage door opens when i do that
post Jan 3, 2010 - 1:40 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
QUOTE (freddy121389 @ Jan 2, 2010 - 5:23 PM) *
And does it go down when you disconnect them, or do you need to send the signal again to close it? If the latter, that would indicate the button is meant to be an interrupt switch, while you need a button which creates continuity when pressed.
Lo-Fi Version Time is now: February 22nd, 2025 - 4:06 AM
