Want to remove the ABS controller in the engine bay, What do I need to know? |
Dec 22, 2009 - 9:59 AM |
Enthusiast Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
I want to temporarily remove this:
(photo courtesy Batman722) Assume I know nothing. This post has been edited by BloodyStupidDavey: Dec 22, 2009 - 10:03 AM -------------------- Davey
Items for sale |
Dec 22, 2009 - 10:05 AM |
Enthusiast Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
you can't and you shouldn't... the lines run from the brake cylinder to the abs controller to the brakes.... soooo... you would need all new lines in order to reroute it around the ABS controller... plus you have a 99 which has the upgraded controller... why would you want to remove it?
-------------------- Breaking Axles...
Dec 22, 2009 - 10:15 AM |
why would you want to remove it? I'm doing some work in the engine bay and need access to that area while carrying out the work. I will put the unit back before driving the car. What I really want to know is, 1 is the brake fluid under pressure there? 2. can I drain the brake fluid off before attempting other work? 3. can I undo the nuts that hold the brake lines onto the abs unit? 4. will I be able to roll the car with the abs unit missing? 5. can I refill the brake fluid and then just drive the car? 6. any specific procedure for draining or refilling the brake fluid? Cheers, This post has been edited by BloodyStupidDavey: Dec 22, 2009 - 10:15 AM -------------------- Davey
Items for sale |
Dec 23, 2009 - 3:11 AM |
Enthusiast Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
Just a Random Question but is that a Soda Can behind your driver side Strut Tower?
Dec 23, 2009 - 3:30 AM |
Enthusiast Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) |
1 is the brake fluid under pressure there? 2. can I drain the brake fluid off before attempting other work? 3. can I undo the nuts that hold the brake lines onto the abs unit? 4. will I be able to roll the car with the abs unit missing? 5. can I refill the brake fluid and then just drive the car? 6. any specific procedure for draining or refilling the brake fluid? Cheers, 1. No, it's not under pressure 2. Sure, but you won't be able to remove all of the fluid. 3. Yes you can, you'll need a open wrench like this one to avoid any damage: Only you need a size 10 4. Sure, but you'll only have your handbrake. 5. Yes, as long as you bleed the system properly. 6. Pressurize the brake system by pumping the pedal, open the bleed plugs on the caliper to let air out. repeat this several times until no more air is coming out. Start with the longest brakeline and work your way to the shortest one. So first right rear, then left rear, right front, left front. It's a 2 mens job unless you have this: This post has been edited by nsxtypeR: Dec 23, 2009 - 3:31 AM -------------------- JDM ST205
Dec 23, 2009 - 3:49 AM |
[snip response] Awesome response - many thanks! One final question (I think) - from where do I drain the brake fluid? -------------------- Davey
Items for sale |
Dec 23, 2009 - 4:13 PM |
[snip response] Awesome response - many thanks! One final question (I think) - from where do I drain the brake fluid? There's a drain plug on the back of each caliper. You're welcome -------------------- JDM ST205
Lo-Fi Version | Time is now: November 30th, 2024 - 8:52 PM |
