Help Transmission gear ratio's |
Dec 24, 2009 - 9:29 PM |
Enthusiast Joined Jan 17, '06 From Wisconsin Currently Offline Reputation: 0 (0%) |
Hello I have been searchiing for a while now and can't find the exact specs on what the gear ratios are for my 94 celica's gt 5 speed gearbox?
Also what is the transmission called? Is it a C56? I can't find the specs anywhere......... I am trying to compare it the MR2's gear ratios for a possible swap...... Thanks..... |
Dec 24, 2009 - 9:47 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Dec 24, 2009 - 10:23 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
94-99 Celica GT tranny is S54
94-99 Celica ST tranny is C52 This post has been edited by Remy: Dec 25, 2009 - 4:55 PM -------------------- "To Protect And To Serve The Wealthy" -POLICE
Dec 24, 2009 - 11:40 PM |
Thanks guys I can't believe the specs where here all along. As for the e153 there is a sticky article on this website stating how to install it. I don't understand why it wouldn't work?????
thanks.... |
Dec 25, 2009 - 4:56 AM |
Enthusiast Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
Thanks guys I can't believe the specs where here all along. As for the e153 there is a sticky article on this website stating how to install it. I don't understand why it wouldn't work????? thanks.... e153 works fine, its a fairly easy install. you just need a new set of shifter cables and st185 out/mr2 half shafts for axles. |
Dec 25, 2009 - 5:44 AM |
c56 tranny has an lsd and comes from the toyota levin with 4age blacktop, which is not compatible with the s series motors like the 5sfe and 3sge.
Dec 25, 2009 - 4:55 PM |
Thanks guys I can't believe the specs where here all along. As for the e153 there is a sticky article on this website stating how to install it. I don't understand why it wouldn't work????? thanks.... e153 works fine, its a fairly easy install. you just need a new set of shifter cables and st185 out/mr2 half shafts for axles. Yeah ur right it will work but I think the gears are longer for the e153 and like stated u need custom axles. I just don't think u want to go through all that for lsd when u can just put one in your s54 and don't have to deal with the axle problems. This post has been edited by Remy: Dec 25, 2009 - 4:57 PM -------------------- "To Protect And To Serve The Wealthy" -POLICE
Lo-Fi Version | Time is now: November 30th, 2024 - 5:59 PM |
